Thread: Engine Management Guage Not Workin
Results 1 to 16 of 16
SuperChargedMook Engine Management Guage Not... 02-26-2009, 11:29 PM
Guest Re: Engine Management Guage... 02-26-2009, 11:44 PM
SuperChargedMook Re: Engine Management Guage... 03-02-2009, 10:26 PM
BrokeMofugga Re: Engine Management Guage... 03-02-2009, 11:16 PM
02BlueGT Re: Engine Management Guage... 03-02-2009, 11:37 PM
BrokeMofugga Re: Engine Management Guage... 03-05-2009, 10:03 AM
DanGTP Re: Engine Management Guage... 03-05-2009, 12:57 PM
SuperChargedMook Re: Engine Management Guage... 03-11-2009, 07:57 AM
DanGTP Re: Engine Management Guage... 03-11-2009, 02:05 PM
SuperChargedMook Re: Engine Management Guage... 03-12-2009, 07:34 AM
DanGTP Re: Engine Management Guage... 03-12-2009, 11:46 AM
SuperChargedMook Re: Engine Management Guage... 03-15-2009, 10:14 PM
DanGTP Re: Engine Management Guage... 03-16-2009, 01:09 AM
SuperChargedMook Re: Engine Management Guage... 03-16-2009, 07:28 PM
DanGTP Re: Engine Management Guage... 03-16-2009, 08:13 PM
SuperChargedMook Re: Engine Management Guage... 03-22-2009, 10:11 PM
  1. #1 Engine Management Guage Not Workin
    Feb 2009
    Missouri
    I have a 01 GTP i bought last week. i was wondering if anyone knows whats goin on with my dash's engine management gauge? it doesnt illuminate. i know it probablyy has something to do wit my obdII because it also doesnt work. i tried to get an emission and they said it didnt work. please help. i have about 25 days to get my plates.
  2. #2 Re: Engine Management Guage Not Workin
    TDCRacing
    Guest
    Check all of you're fuses and let us know how that goes. Are you refering to you're DIC?
  3. #3 Re: Engine Management Guage Not Workin
    Feb 2009
    Missouri
    i checked the dic fuse. its good.
  4. #4 Re: Engine Management Guage Not Workin
    Jan 2009
    Brandon FL
    I also have this problem.im going to keep checking in also what is a dic fuse
  5. #5 Re: Engine Management Guage Not Workin
    Hoffman/Schaumburg, IL
    The Obd port runs off the Cigarrette lighter/Accessory outlet fuse, check that one.... if the fuse is fine, you may have a harness issue
  6. #6 Re: Engine Management Guage Not Workin
    Jan 2009
    Brandon FL
    Whats a DIC fuse and where is it located?sorry about the hijack lol
  7. #7 Re: Engine Management Guage Not Workin
    Feb 2008
    The fuse you're looking for will be in the fuse panel next to the glove box. It'll be labeled "lighter" or "cigar" or something similar. I believe it is a 10-15 amp fuse. Usually if the OBDII port doesn't function, that fuse is blown. Also, on many vehicles (I'm not 100% sure on our cars), when that fuse blows, it can cause the CEL to come on.
    The DIC not lighting up is usually due to the bulbs behind the display being burned up. It's fairly common on our cars.
  8. #8 Re: Engine Management Guage Not Workin
    Feb 2009
    Missouri
    i checked the cigarette lighter fuse, n it was ok. damn! but i have yet to check al of them because its sooooo freakin cold.lol what is the CEL?
  9. #9 Re: Engine Management Guage Not Workin
    Feb 2008
    The CEL is your check engine light.
  10. #10 Re: Engine Management Guage Not Workin
    Feb 2009
    Missouri
    Ok, the fuses r ok. I notice on a bright day when the sun was at its high. The sun rays beamed brightly on the dash. I noticed that every thing is still working, i can see all the numbers moving, the boost gauge increasing. But why wont it illuminate? Everything else on the dash illuminaates perfectly. Is it a fuse just for the hud illumination?
  11. #11 Re: Engine Management Guage Not Workin
    Feb 2008
    It's most likely the illumination.
  12. #12 Re: Engine Management Guage Not Workin
    Feb 2009
    Missouri
    so do i have to replace the whole guage?
  13. #13 Re: Engine Management Guage Not Workin
    Feb 2008
    You should be able to go in and replace the bulbs. I believe they may be soldered in.
  14. #14 Re: Engine Management Guage Not Workin
    Feb 2009
    Missouri
    ok thanks. is there any links that'll show me how to get to it? i dont know how to take out the dash?
  15. #15 Re: Engine Management Guage Not Workin
    Feb 2008
    I don't know of any how-to's on it. You'll have to remove the colored trim piece that goes in front of it (It should pop out) to access the DIC.
  16. #16 Re: Engine Management Guage Not Workin
    Feb 2009
    Missouri
    ok, here goes nothin,lol
  1. Outside teperature guage
    By mattio in forum General Tech Discussion
    Last Post: 02-15-2009, 05:00 PM
  2. Manifold Air Temp Guage?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 05:24 PM
  3. Replies: 5
    Last Post: 05-12-2008, 01:51 AM
  4. 5 Minute Management Trainning
    By webracin in forum Off Topic Discussion
    Last Post: 02-15-2008, 02:33 AM
