Thread: Gas guage stays on full.
Results 1 to 7 of 7
  1. #1 Gas guage stays on full.
    Utah
    I just got a 2001 GTP 3 weeks ago. I put 15 gallons in the tank then. My wife a week ago ran it out of gas and tried to start it for a minute. I put a couple gallons in and took it and filled it all the way up to the top of the neck. Anyway it's been a week and the gas gauge still reads full and the D.I.C. still shows 359 miles but shows I've used 15.1 gallons and the trip odometer shows 302 miles. Three times today my wife said it fluctuated from full to empty then goes back to full and the D.I.C. dropped to normal.
    Any Ideas?
  2. #2 Re: Gas guage stays on full.
    Utah
    I pulled the cover off of the fuel pump it all looks OK. I cleaned it off and checked the connections even with the key just turn forward it goes up and down but mostly stays on full i just disconnected the battery to see if maybe it will work. I'm going to try tearing into the dash to check the display light for the stereo and I'm going to check around for something wrong behind there.
  3. #3 Re: Gas guage stays on full.
    Utah
    couldn't find anything and now the D.I.C. is so dim you can't hardly see it. I just filled the tank and it's still going up and down.
  4. #4 Re: Gas guage stays on full.
    SE Level Member 1992GrandPrixSE's Avatar
    Central Ohio
    It sounds to me like you may have a corroded variable resistor in your fuel sending unit. Try adding a bottle of Techron Concentrate fuel additive. You can find this at just about any place that sells automotive products. I had a very similar issue in a Grand Am I used to own. A few Techron treatments fixed the problem.
  5. #5 Re: Gas guage stays on full.
    Barksdale AFB, LA
    It's the fuel level sensor. Common issues on w-bodies.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Gas guage stays on full.
    Nov 2008
    Chicago
    Quote Originally Posted by Sabrewings View Post
    ^ x2
  7. #7 Re: Gas guage stays on full.
    Utah
    Thanks I'll give it a shot.
  1. OEM Radio Clock stays on?
    By 100 BUX in forum General Tech Discussion
    Last Post: 03-16-2009, 01:58 PM
  2. Stays Parked in Drive...?
    By 100 BUX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2009, 09:59 AM
  3. Outside teperature guage
    By mattio in forum General Tech Discussion
    Last Post: 02-15-2009, 05:00 PM
  4. Engine light stays on - '99 GT
    By 149GP in forum General Tech Discussion
    Last Post: 09-17-2008, 11:15 PM
  5. Stays in first!
    By silvermistGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-26-2008, 02:42 PM
