Thread: Sirius XM Module Location
Results 1 to 11 of 11
  1. #1 Sirius XM Module Location
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Just put in what is allegedly a brand-new head unit, because it was cheaper and easier (supposedly) than unlocking the one I had. It shows no signs of playing satellite radio. The system in my car has been "upgraded" except for the head unit. I think the XM module's been removed or disconnected. I have the one from my deceased car, but I need to know the location where it goes.
  2. #2 Re: Sirius XM Module Location
    St. Louis
    Check the trunk, drivers side by the taillight, under the trim panel.le is located in the trunk, driver side by tail lamps under trim panel.
  3. #3 Re: Sirius XM Module Location
    Jul 2016
    Brevard County, FL
    Quote Originally Posted by FordMan77 View Post
    There's two black wires wrapped together with electrical tape and becoming one black wire which is attached to the trunk floor. The two wires which need to go in the back of the XM module are nowhere to be seen. So...maybe not?
  4. #4 Re: Sirius XM Module Location
    Jul 2016
    Brevard County, FL
    My shadetree mechanic thinks the module was in the center of the rear deck. Looked there. The two necessary cables aren't there.
    Does ANYONE know the answer?
  5. #5 Re: Sirius XM Module Location
    GT Level Member mguzzo's Avatar
    Buffalo NY
    this document references the right front passenger compartment. I would check behind the radio or up under the dash behind the glovebox.
    https://www.siriusxm.ca/wp-content/u...MClass2Bus.pdf
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Sirius XM Module Location
    Jul 2016
    Brevard County, FL
    1. I am certain my mechanic did not go in either of those locations to remove it from my departed GXP.
    2. I have a 2008.
  7. #7 Re: Sirius XM Module Location
    Buffalo NY
    does your car have a shark fin where you can follow the wire into the cabin?
    2008 Pontiac Grand Prix GXP Antenna
  8. #8 Re: Sirius XM Module Location
    Jul 2016
    Brevard County, FL
    Quote Originally Posted by mguzzo View Post
    1. This link won't open on my desktop. When I use Google, it gives me this. Antenna & Radio for 2006 Pontiac Grand Prix | GMPartsNow Where did you find this?
    2. I can see it on my phone. If I'm interpreting it correctly, which is difficult because the XM module isn't actually shown in the car, it's down under the floor of the trunk, and/or in the bumper. Am I reading this wrong?
  9. #9 Re: Sirius XM Module Location
    Jul 2016
    Brevard County, FL
    Antenna & Radio for 2008 Pontiac Grand Prix | GM Parts Center
    And, again, and this one SAYS "2008."
  10. #10 Re: Sirius XM Module Location
    Buffalo NY
  11. #11 Re: Sirius XM Module Location
    Buffalo NY
  1. sirius xm radio
    By SgtMarshal in forum Off Topic Discussion
    Last Post: 10-16-2015, 12:49 PM
  2. 2004 Grand Prix GT - installing XM/Sirius
    By Scott Gerhart in forum Audio, Security & Visual Electronics
    Last Post: 08-14-2012, 02:15 PM
  3. Dual climate control module location
    By boosted99 in forum General Tech Discussion
    Last Post: 12-10-2011, 02:39 PM
  4. Can the stock XM antenna be used with Sirius
    By zx7r4u2nv in forum Audio, Security & Visual Electronics
    Last Post: 04-09-2011, 06:09 PM
  5. Show your Sirius and XM sat radio setups!
    By lbrowne in forum Audio, Security & Visual Electronics
    Last Post: 03-10-2011, 12:30 PM
