Thread: Passenger Window slow
Results 1 to 6 of 6
  1. #1 Passenger Window slow
    Feb 2021
    Bucks County, PA
    Hi,
    My passenger side window is slow ... I'm figuring it's the window's motor going bad. Is that called a REGULATOR ASSEMBLY in GM terms?
    And would this be correct? (It's the right model vehicle, I just want to make sure it's PASSENGER SIDE (RH?) and the part that will do the fix.
    Thanks,
    Tom
  2. #2 Re: Passenger Window slow
    GT Level Member mguzzo's Avatar
    Buffalo NY
    coupe or sedan?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Passenger Window slow
    Buffalo NY
    but to answer your questions - yes passenger side is RH and driver is LH.
    The part comes as an assembly with the motor and regulator.
  4. #4 Re: Passenger Window slow
    St. Louis
    I'd bet if you cleaned up the felt guides in the door frame and lubed them up that window would speed back up. Common issue on these cars. The guides start to drag on the glass and then you start eating window regulators like candy. Could be worth a try before having to tear the door panel off.
    FWIW, I still have all of my factory window motors on my '00 GT. I just order the regulator by itself when one breaks and swap my motor onto it.
  5. #5 Re: Passenger Window slow
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Quote Originally Posted by FordMan77 View Post
    And this wouldn't result on lube smeared all over the glass because?
  6. #6 Re: Passenger Window slow
    St. Louis
    Because you would use a "dry film" silicone lube that won't migrate much out of the guides and onto the glass. Do not use white lithium grease, WD-40, regular silicone, bearing grease, etc. as they can harden up when dried/cold or attract more dirt to the guides and cause further issues.
    Also, if you have to pull the door panel I would check the guides top to bottom to make sure they aren't pinched somewhere. If a door mirror gets damaged it can pinch the guide just enough to make it drag more than it should. Had that issue on an '01 recently.
  1. Window Rolls Up Slow or Not at All
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-02-2010, 05:35 PM
  2. Passenger window will not roll all the way up
    By kevinpope in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2010, 05:39 PM
  3. passenger window problem.. LOOK
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 12:50 AM
  4. Why is my passenger window p*ss slow?
    By Z28 in forum General Tech Discussion
    Last Post: 03-25-2009, 09:41 PM
  5. slow drivers side window
    By Jakegday in forum General Tech Discussion
    Last Post: 12-21-2008, 12:58 PM
