If you search on my name you'll likely find the spot to use. Pull back the passenger carpet under the dash, there's a square/rectangle rubber boot that all the main wiring goes through. Comes out on the firewall across from the power steering pump. It can be a pain to send the wire through if you are trying to keep it in the boot proper but it can be done. I did a 4 gauge.
