Thread: Finding a hold in the firewall for power wire!!
Results 1 to 12 of 12
  1. #1 Finding a hold in the firewall for power wire!!
    SE Level Member 03limitedgtp's Avatar
    Sep 2011
    ohio!
    i'm installing my new system but want to do it the right way and run the power wire through the wall does anyone know where a hold is available or safe place where i can drill a hole?
  2. #2 Re: Finding a hold in the firewall for power wire!!
    Mar 2012
    NC
    Well there is a grommet to the D/S of the brake booster that has no wires going through it...you could use that. I've seen a lot of people run it through the harness grommet on the lower P/S of the firewall though.
  3. #3 Re: Finding a hold in the firewall for power wire!!
    Houston
    Man, there have been a ton of these threads lately. Here's a couple just from this week.
    http://www.grandprixforums.net/amp-w...elp-67199.html
    http://www.grandprixforums.net/wirin...rix-67102.html
  4. #4 Re: Finding a hold in the firewall for power wire!!
    Mar 2012
    NC
    The bottom hole in this pic is located just below/behind the brake booster on the D/S.
    I'm not sure if it is easily accessed with the GP brake booster as it is bigger than my current booster, but if I were going to do it all over again, that's what I'd use since it's just a grommet with no wires through it.
  5. #5 Re: Finding a hold in the firewall for power wire!!
    Houston
    It's accessible. That's where my boost gauge line and oil pressure wires are ran. But it's easier to go to the passenger side for the big power wire.
  6. #6 Re: Finding a hold in the firewall for power wire!!
    Sep 2011
    ohio!
    how did u get to the hole under the brake booster on gp?
  7. #7 Re: Finding a hold in the firewall for power wire!!
    Houston
    With a glowrod. Basically a pointy fiberglass stick. Strap your wires to it and push it through. It's still a pain in the ass. Easier to go through on the passenger side.
  8. #8 Re: Finding a hold in the firewall for power wire!!
    May 2012
    Northern Indiana
    Easiest way I found is on the passenger side. Pull the carpet back some and you see a big grommet there makes it easier and uses less wire because the battery is on that side.
  9. #9 Re: Finding a hold in the firewall for power wire!!
    Oct 2013
    Canada
    How did you get through the passenger side grommet? I read that one can poke a cut coat hanger through and then tape wire to coat hanger and run through. This being said, I found the grommet material too tough for my coat hanger. Do I have a different type of grommet or is there another method such as drilling?
  10. #10 Re: Finding a hold in the firewall for power wire!!
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by Car Splicer View Post
    It seems barbaric, but I rammed a screwdriver through the firewall side of the boot, then ran my 4 gauge wire through. I sealed the passenger compartment side with silicone.
  11. #11 Re: Finding a hold in the firewall for power wire!!
    i took the windshield cowl off the pass side, then deep under the windshield i drilled a hole, fed my amp wire right through the hole it dropped down and came out at the floor board.
  12. #12 Re: Finding a hold in the firewall for power wire!!
    Oct 2013
    Canada
    Quote Originally Posted by douger View Post
    Thanks for your input. I managed to find out there is rubber plug in way on 1997-2003 pontiac models. Pull out the plug inside of soft grommet and then poke screwdriver, coat hanger, or fibreglass stick through and run your your power wire through. Extra info for plug: I used screwdriver to pry it up then grabbed with pliers to pull out. It is split in two pieces. You will see when you pull it out.
  1. Where to run power wire through firewall
    By ahl395 in forum Audio, Security & Visual Electronics
    Last Post: 04-23-2012, 10:01 PM
  2. damn car -_-..firewall/power wire fail
    By Dragonblaze in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2010, 10:17 PM
  3. new power wire
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2009, 03:35 AM
  4. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  5. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
