anyone know where ground g201 is looks like it may be the problem since i have other components that went out that are connected to that ground but its wierd all the wires going to the switch are fine and are either grounded or give voltage and the issue seems to be that the resistor is not getting voltage from the grey black wire when the switch is on so I would assume the switch is bad but I have 3 different switches and none of them work?
