Thread: Charging System Failure
Results 1 to 9 of 9
  1. #1 Charging System Failure
    Apr 2013
    White Lake
    2005 GP GT 127k
    Soooo... I run HID's in my car and sometimes when they go on the left doesn't power on so I will turn headlights off then turn them back on then both power on. Last week it happened and when I flipped them off and back on the DLC said "charging system failure". Seemed odd so I was like what ever and went about my day... Today it did it again and it came up on my DLC so I turned of and back on and it popped up on DLC. I also have a relay harness that goes to the battery because before my alt was making a buzzing noise because HIDs and after the buzzing noise went away.
    Any idea what is going out?
  2. #2 Re: Charging System Failure
    Aug 2013
    Kitchener, Ontario
    I just had this happen. Do you have a charge gauge in the DIC? If so, what readings are you getting?
    In my case, the alternator was going bad.
  3. #3 Re: Charging System Failure
    Apr 2013
    White Lake
    I don't unfortunately : /
  4. #4 Re: Charging System Failure
    Enfield, CT
    did you disable the DRL?
  5. #5 Re: Charging System Failure
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Take the car to AutoZone they can test your alternator to see if its going bad. You headlights those sounds like a bad grounds possibly.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: Charging System Failure
    Apr 2013
    White Lake
    No did not disabled my DRL. I will check my grounds.
  7. #7 Re: Charging System Failure
    Feb 2013
    Woodbridge NJ
    Took the alternator for the deceased '04 to Pep Boys and they checked it for me. Said it was good. Reinstalled it and bought a new battery. Next day car shut off again. Replaced the alternator and it ran beautifully after that. So what I am saying is don't put too much credence in an alternator check. Replace it unless you have the time to do the job twice
    Don
    2004 GT1
  8. #8 Re: Charging System Failure
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Quote Originally Posted by Dadillac View Post
    Don
    I typically make them test it 3 or 4 times if it tests good the first run. I can't tell you how many times I got the "It shows good". I would ask them to run it again and usually by the 3rd or 4th time it would start failing their test.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  9. #9 Re: Charging System Failure
    Quote Originally Posted by LeadfootCJ7 View Post
    This! Had it test fine the first 1 or 2 times then I'll have it tested again and it fails the next 2 or 3 more times. I can't tell you how many times I had one pass just to take it back home and install it and then coming out to a dead battery once again.
    04 Comp G.
  1. charging system failure
    By luckyg817 in forum General Grand Prix Discussion
    Last Post: 07-19-2014, 01:30 PM
  2. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  3. Charging system failure w/HID's
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 03-12-2011, 12:37 AM
  4. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
