Thread: Recommend Me a Replacement for Stock Front Speakers
Results 1 to 12 of 12
  1. #1 Recommend Me a Replacement for Stock Front Speakers
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Alright. Need some help here. Been looking on Crutchfield and other sites, but truth be told... I don't know WHAT the fukk I'm looking at. Non-of these numbers mean anything to me, nor to the brands. I just want direct Plug-n-Play speakers for the front doors, with tweeters. Just like the original setup. I don't wanna have to mess around with amps, re-wiring, or some other bull****.
    Is there anything that is stock quality or better, that I can just plug-in and mount without any additional trouble?
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  2. #2 Re: Recommend Me a Replacement for Stock Front Speakers
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Well, there's really two options here. Replacing stock with stock, or upgrading.
    You can either grab a pair of 5 1/4" speakers for the doors and some tweeters (or run the composite ones with integrated tweeters and have less to worry about) and use these adapters: Amazon.com: Metra 72-4568 Speaker Harness for General Motors (2 Pairs): Computers & Accessories If you reuse the stock tweeter, it has a crossover built in, so just wire it's positive with speaker positive on the adapter and so on. If you upgrade your tweeter, a good set will have you wire in a crossover, so get ready for complexity. Easiest is using composite speakers, next hardest is re-using stock tweeter, hardest is wiring in separate component speakers.
    If all you want is to replace blown out speakers, then this is your easiest option by far: ACDelco(R) - Pontiac Grand Prix 2000 GM Original Equipment™ Radio Speaker or just pm me and I'll pick some up at the junkyard.
  3. #3 Re: Recommend Me a Replacement for Stock Front Speakers
    GT Level Member Going Too Phast's Avatar
    I just upgraded my sound system for the fun of it over the course of a few months. wstefan20 is right. For simplicity, 5.25" coaxial speakers are going to be the best bet. The factory setup is component with separate tweeters and woofers, so a coaxial won't be the same. But just about any pair of coaxials should be a step up from the factory stuff. Especially 20 year-old factory stuff.
    I'd recommend looking for coaxial 5.25" speakers that will work within your budget. I put in some 5.25" Morel Tempo Ultra coaxials for my front speakers and I am very happy with them. Just bolt in and go really. I ran them off of my aftermarket head unit for a few weeks before adding an amp and they worked fine like that. Morel has some more affordable speakers (i.e., Maximo) as well, but any decent brand should be a noticeable improvement.
  4. #4 Re: Recommend Me a Replacement for Stock Front Speakers
    Dec 2015
    Chicago, IL
    Ok. Cool. Thanks for the explanations. Looks like I'm gonna go junkyard hunting myself. Have to save money where I can and audio crap can wait. The current front speakers are straight up punctured, so they're in terrible shape. Probably something I did. The door panels have been off for a while now. I'm sure something poked them, dropped on them or something.
    Do you know if any other cars share these exact speakers. Like a Park Avenue or Bonneville even? The speakers are more likely top be in good shape from some granny-mobile ....listening to AM radio all day long.
    243,000 miles
    CHICAGO, IL
  5. #5 Re: Recommend Me a Replacement for Stock Front Speakers
    Aug 2017
    Raytown, MO
    I would assume any 5.25" will work. If you don't want to do any wiring though, look for any gm set that has separate tweeters. Look on the back of your stock speakers and you'll see the plugs you need to look for. Almost all gm speakers from that era used those connectors. Good luck!
  6. #6 Re: Recommend Me a Replacement for Stock Front Speakers
    Jul 2010
    Coquitlam,BC,Canada
    Unless you want to get creative, toss some 5.25's in and be done with it. I got some AVI's from a co-worker for cheap.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Recommend Me a Replacement for Stock Front Speakers
    Aug 2017
    Raytown, MO
    If anyone comes across this thread looking to upgrade to 6.5" etc., the easiest way (and least modification) that I've found is to use a cutoff wheel to make a "box cut" at the angle of the speaker at the top. Essentially you'll be cutting an upside down bullet shape and removing the top of the plastic bracket and cutting into the door a bit. The speaker will then tilt at the factory angle and still point towards the listener, and you can secure with 2 screws in the stock location at the bottom of the bracket. Of course, you'll want to sand and paint the bare cut metal, but it's three cuts and done. This way you don't have to modify the bracket or worry about the window not working or modifying the door panel. Oh, and there's a nice cavity right above the speaker where you have nearly 3/4" depth room to fit a crossover behind the door panel. I usually glue aftermarket tweeters in the stock location and they sound great. I'll try to throw up a few pictures when I have time.
  8. #8 Re: Recommend Me a Replacement for Stock Front Speakers
    Jul 2010
    Coquitlam,BC,Canada
    Picture of speaker bracket.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Recommend Me a Replacement for Stock Front Speakers
    Dec 2015
    Chicago, IL
    @Bronco Boy
    So what you're saying is get some composite 5.25" and that's it? Will any 5.25's work?
    I do not have Bose. That might matter.
    And,... did you you have to do anything with the bracket to fit the aftermarket speakers? Do I need any kind of wiring adapter for the plugs?
    I wanted the whole tweeter assembly like original setup, but now I'm thinking Fuk it. Speakers are pretty cheap new
    243,000 miles
    CHICAGO, IL
  10. #10 Re: Recommend Me a Replacement for Stock Front Speakers
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by CHI2000GTP View Post
    @Bronco Boy
    Remove old speaker, adapt wiring, install new speaker. That is it. Any 5.25 should fit. No Bose here either. No modifications to the bracket.
    Here is my install: Front_Speakers
    I didn't put the tweeters in as one had the wiring ripped out of it. They would have dropped right in though one the outer housing was removed.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Recommend Me a Replacement for Stock Front Speakers
    Aug 2017
    Raytown, MO
    Agreed, and the adapters though not really needed are listed in my post above and make the install plug and play for aftermarket speakers
  12. #12 Re: Recommend Me a Replacement for Stock Front Speakers
    Dec 2015
    Chicago, IL
    Quote Originally Posted by wstefan20 View Post
    Yes. Saw that. Thanks man. Saved me some time looking around.
    243,000 miles
    CHICAGO, IL
  1. Front door speakers and rear deck speaker replacement
    By Cruz in forum Audio, Security & Visual Electronics
    Last Post: 04-08-2013, 06:47 PM
  2. New Front Speakers, Had To Disable Stock Tweeter?
    By SuperSport in forum Audio, Security & Visual Electronics
    Last Post: 08-28-2012, 04:51 PM
