Thread: 04+ Radio Bench Test Hookup Help
Results 1 to 12 of 12
  1. #1 04+ Radio Bench Test Hookup Help
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Well, I'm attempting to bench test an 04+ base radio and so far have been unsuccessful. Here's the pinout I have, and I'm not sure what is correct.
    Purple writing is for other gm stereos that use the same plug and aren't used on this radio.
    Highlighted parts I have wired to battery. 15Amp fuse on B1 and 5Amp on B4 just to be safe.
    CD player makes the "turn on noise" and the lights on every other bulb turns on. Haven't hooked up a speaker yet so that's next. There's absolutely no backlight or display even dim.
    When I took the radio apart, I noticed all three bulbs were burnt out so I replaced them and tested the bulbs both out and after installation.
    Pretty sure this radio is toast, but I figured I'd post this before I get a new one a screw it up too.
    And yes, I have to bench test because I only own a 2002 so....
  2. #2 Re: 04+ Radio Bench Test Hookup Help
    theres a good chance its locked, they dont tent to work outside the car or in a different car. search youtube for unlocking it, for some theres a way to enter a code to unlock it.
  3. #3 Re: 04+ Radio Bench Test Hookup Help
    Aug 2017
    Raytown, MO
    I think you're right. I wired up a speaker and started playing around with it some and found something interesting. The display actually comes on with the time and lights up when you push the tune button, but doesn't stay lit for a few seconds then it goes off. Only buttons that I can tell are working are the hour and minute button can change the time and the tune can illuminate the display, but that's it. Theft light isn't lit. Just strange... Anyone seen this before? I'll try googling and see what I can find.
  4. #4 Re: 04+ Radio Bench Test Hookup Help
    Aug 2017
    Raytown, MO
    Well, I think I might have found the problem, but not sure if there's a solution. Turns out that this is normal behavior for the radio with no key in the ignition. Now normally there's an ignition wire that tells the radio that it's ok to turn on, but unfortunately, at least with the stock wiring, there is no ignition wire so I'm assuming the signal is through class 2 data?
    On the metra harness, there's a pin B2 that isn't present on the grand prix that's supposed to be ignition voltage. On the radio, there is a pin for B2. I'm wondering if it wold work to just insert that wire and connect it to power.
    I think I'm going to give that a shot since there were a dozen of these radios in the junkyard, and I can easily grab another one if this shorts it out and exchange for free.
  5. #5 Re: 04+ Radio Bench Test Hookup Help
    Aug 2017
    Raytown, MO
    Nope, no change. I'm suspicious that there's nothing wrong with the unit other than it doesn't have class2 data telling it it's on. I'll try with another junkyard unit and if I get the same result, I'll know.
  6. #6 Re: 04+ Radio Bench Test Hookup Help
    How to unlock gm radios 2000-2005 - YouTube theres this way. but ive seen other vids where they take a chip out and iirc the memory stops working for the clock and pre sets. theres a ton of others vids to watch as well.
  7. #7 Re: 04+ Radio Bench Test Hookup Help
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    If you want the legitimate wiring diagrams, look no further:
    04+ Factory Service Manuals, Owner's Manuals, and assorted helpful info.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  8. #8 Re: 04+ Radio Bench Test Hookup Help
    Aug 2017
    Raytown, MO
    I don't think it's theft locked. Or, at least it isn't turned on enough to say it is. From all the videos I've seen, the theft lock led will illuminate, and the radio will display "locked". None of the videos I saw had anything like I did. I also noticed that all the videos on replacing the backlights didn't bench test them but tested them directly in their car, so I'm thinking that's a reason.
    I think at this point, I'll try removing the security chip, and if that doesn't do anything, I'll see if someone here wants to give it a shot for me in their 04+ gp. (I'd pay shipping both ways of course). Idk, maybe this chip removal does something
  9. #9 Re: 04+ Radio Bench Test Hookup Help
    this guys got em working on a bench.
    https://youtu.be/DhMOmSMijXI?t=430
  10. #10 Re: 04+ Radio Bench Test Hookup Help
    Aug 2017
    Raytown, MO
    Quote Originally Posted by WarStryker13 View Post
    Thanks man! Looks like my info is correct. I'm leaning toward class2 data not present is the only issue, but I'll try a few more things.
  11. #11 Re: 04+ Radio Bench Test Hookup Help
    Oct 2014
    Frederick, MD
    Quote Originally Posted by wstefan20 View Post
    If I still had my factory stereo wiring plugs, I would totally do this... But the PO hacked the current HU into this car, and since it's actually a decent HU, I haven't really had much inclination to mess with it.
    I did have to fix their mistakes when they wired it in, which led to me acquiring those FSM's... From looking at those and remembering what I had to go through, the factory radio needs a signal from IGN +12v and possibly the park lamps. I would try adding +12v to those first.
  12. #12 Re: 04+ Radio Bench Test Hookup Help
    Aug 2017
    Raytown, MO
    Yeah. I found on another forum that it looks like these newer radios use class2 via the bcm to tell the radio to turn on instead of ignition voltage. I think I'll just have someone test one for me in the car, but at least I know all the lights and display works!
  1. Easy bench harness 99+ and 04+
    By 04whitegtp in forum How To Write-Ups/Tech Tips
    Last Post: 05-22-2016, 11:21 PM
  2. dyno or bench tune?
    By SleeperGS in forum General Tech Discussion
    Last Post: 04-08-2014, 04:29 PM
  3. Bench racing
    By TEK310 in forum Track Sessions and Kills
    Last Post: 02-16-2014, 08:58 AM
  4. Bench Test Driver Information Center (DIC)
    By jejensen in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2011, 08:26 PM
  5. New work bench
    By Black18Ice in forum Off Topic Discussion
    Last Post: 01-02-2010, 09:24 PM
