Thread: Stereo wiring revisited..
Results 1 to 20 of 20
  1. #1 Stereo wiring revisited..
    Nov 2017
    Ravenna Mi
    I have been scouring the the threads here and elsewhere trying to figure out the wiring to install this stereo. I have the speaker and power, (constant and switched) and ground figuredout. But there are two wires that have me confused.
    Here's the harness in the car...
    Orange - Constant pwr
    Yellow - switched pwr
    Grn/blk - ?
    Brn/wht - ?
    Grey/blk - illumination ?
    Blk/wht - ground
    The corresponding harness to the radio looks like this:
    Yellow -> orange
    Red -> Yellow
    Blue- ->Grn/blk
    Orange -> brwn/wht
    - blank -> grey/blk
    Blk -> Blk/wht
    (the 4 wires on the far right are speaker wires...I think )
    So, on the white harness, what are the blue and orange wires for?
    Thanks,
    MB
  2. #2 Re: Stereo wiring revisited..
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    These should be what you need:
  3. #3 Re: Stereo wiring revisited..
    St. Louis
    Not sure what year this is for (maybe a 97?). What stereo are you trying to install? Stock, aftermarket?? Need some info here. If it's an aftermarket deck then you can likely get a harness adapter for it without worrying what wire is which and cutting the stock harness up. I installed a new Alpine in my 00 GT with a plug and play adapter and also retained my steering wheel controls with another adapter.
  4. #4 Re: Stereo wiring revisited..
    Nov 2017
    Ravenna Mi
    Quote Originally Posted by FordMan77 View Post
    Sorry... 97' GTP, Stereo is an off-brand aftermarket. I just got this car used and it had no stereo in it, but the harness to the head unit is there. Here's the wiring schematic for the stereo;
  5. #5 Re: Stereo wiring revisited..
    they sell a plug with marked wires on it that will plug into the factory plug there, then run the pig tail to the new radio. easy peezy.
  6. #6 Re: Stereo wiring revisited..
    Nov 2017
    Ravenna Mi
    Thanks Wstefan20, that looks like exactly what I needed!
    I'm thinking I will have to get a steering wheel interface kit to use my stock steering wheel controls?
  7. #7 Re: Stereo wiring revisited..
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Mad Bohemian View Post
    Yup. Though I agree with Scotty, it's much easier just to get the harness. Good luck!
  8. #8 Re: Stereo wiring revisited..
    Nov 2017
    Ravenna Mi
    Well, it's
    Car - 1
    Me - 0 .. in triple overtime :P
    Actually I got everything installed and working (didn't do the steering wheel controls at this time) Back up camera, GPS everything works fine.... except for the passenger side front speaker. So I did some trouble shooting. Verified that the speaker is fine and I have output from the unit to through the wiring harness with an ohm meter. Both wires in the door have no continuity to the wiring harness, so I started stripping the passenger side of the dash down. Took off the glovebox door and the kick panel 'shelf' that goes to the firewall, that's when I noticed this plug handing down:
    You can see another plug to the right nearby, but they do not reach each other and the are not compatible..
    This is the plug on the right
    this is plug on the left
    This is where it gets crazy....The plug on the right has the same dark green and bright green wires that the wire harness has, so just for grins I did a continuity check from the wire harness at the stereo to that plug
    I get continuity !! Like I said, all the other speakers work so I am at a dead end at to why the passenger door doesn't have any continuity, and why this plug does... Anyone know what the plug under the dash is for?? BTW, the plug on the left has matching wire colors as well, but no continuity to the speaker wires in the door either. If I have to I can run new wires to the door, but that's a real PITA...any ideas guys? Just want to make sure to PO didn't disconnect stuff and just leave it hanging that is needed...
  9. #9 Re: Stereo wiring revisited..
    Aug 2017
    Raytown, MO
    I know some vehicles of this era had a "Monsoon" delco amp located right about there, which could explain the plugs. Let me see what I can unearth. Did everything work before the radio swap? Or is this what started it?
  10. #10 Re: Stereo wiring revisited..
    Aug 2017
    Raytown, MO
    So I can't say for sure since I have a 1998 manual, and apparently these were ONLY in select 1997 GTPs. This interestingly is where the myth started that the bose amplifier doesn't actually amplify the front speakers. This: http://www.grandprixforums.net/threa...bout-stock-amp little baby amp is what should be there. I've seen a few in the junkyard, but never peaked my curiosity. Apparently, no one has the pinout for these connectors at all! I'm going to try to locate one of these in the junkyard and use a test light to at least find the color configuration for the front door speakers. I'll let you know.
  11. #11 Re: Stereo wiring revisited..
    Nov 2017
    Ravenna Mi
    This car had no stereo when I got it. I was thinking maybe something went between these two plugs (like an amp) but then shouldn't I have the same problem with either the other front speaker, or the right rear speaker too...? That's what has me confused...
  12. #12 Re: Stereo wiring revisited..
    Aug 2017
    Raytown, MO
    I agree with your conclusion there, and the fact the radio was missing points me towards audio work. It is possible that the rear speakers have been spliced into somewhere are re-wired, causing this. I would see if you can see any "custom" wire work behind the dash. I'd double check your wiring too just in case. Personally I wouldn't mess with it and just run new wires, the stock ones are way too small for my taste anyhow. But I'll see if I can't make my own wiring diagram from junkyard cars tomorrow.
  13. #13 Re: Stereo wiring revisited..
    SE Level Member 1FastGP's Avatar
    May 2015
    Indian Trail, NC
    That connector is for the 97/98 only premium sound system amp. If you have 4 speakers in the back window you have that system. Without the amp there the 6x9's in the back will not work but the small ones will. That amp doesn't power the front speakers but is spliced to them.
    Sent from my SM-G955U using Tapatalk
  14. #14 Re: Stereo wiring revisited..
    May 2015
    Indian Trail, NC
    There's a diagram of the connector for ya.
  15. #15 Re: Stereo wiring revisited..
    Aug 2017
    Raytown, MO
    Quote Originally Posted by 1FastGP View Post
    I almost sent the same diagram, however that's the exact one for the bose amp. I'm curious if it is the same or different especially since there's two plugs! I'd double check everything on this chart and be skeptical of everything
  16. #16 Re: Stereo wiring revisited..
    May 2015
    Indian Trail, NC
    I got that diagram off all data so it should be right I used it to reinstall the same amp in my 98 after the p.o. cut the connector and took the amp out. Knowing gm they probably used the same connector just moved it to the trunk for the bose setup in 99
  17. #17 Re: Stereo wiring revisited..
    Aug 2017
    Raytown, MO
    Nice! That's good to know. I wonder what the pinout of the second connector is though, and what wires need to be spliced. My experience is mainly with the factory bose amp. I've done way too many stupid upgrades to my car.
  18. #18 Re: Stereo wiring revisited..
    May 2015
    Indian Trail, NC
    Quote Originally Posted by wstefan20 View Post
    I don't really know on that other connector under there all 3 of my GP's have it and it's never had anything plugged into it in any of them and I don't think it has anything to do with the radio.
  19. #19 Re: Stereo wiring revisited..
    Aug 2017
    Raytown, MO
    well that just gives me an excuse to rip a grand prix to shreads in the junkyard to find out! haha
  20. #20 Re: Stereo wiring revisited..
    Aug 2017
    Raytown, MO
    Confirmed, that's the 97 amp plug. I'm still at a loss what the other plug is for. Traced it back as far as I could. I think it's for some other accessory that another w body car has but not ours since it was unplugged on three 97 gtps in the junkyard. I'm really curious now!
  1. 06 stereo wiring harness diagram
    By 86transam in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2016, 11:18 AM
  2. wiring diagram 97-03 stereo with bose where there few wires do?
    By wild2crazy in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2014, 10:14 AM
  3. Coolant leak revisited
    By JaredR215 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2013, 12:06 PM
  4. Special wiring harness for aftermarket stereo for newer gp
    By MattTheBaker123 in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2012, 12:28 AM
  5. wiring harness aftermarket stereo
    By LeThAlREMiX in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2011, 12:41 AM
