Thread: Backup Camera Install
Results 1 to 14 of 14
05BGCrystal Backup Camera Install 02-06-2013, 12:59 AM
REDCRAPGP Go for it. It's rather simple... 02-06-2013, 01:01 AM
Explicit_Spade Re: Backup Camera Install 02-06-2013, 01:29 AM
KeithGTP03 Re: Backup Camera Install 02-06-2013, 01:41 AM
Explicit_Spade Re: Backup Camera Install 02-06-2013, 01:43 AM
KeithGTP03 Re: Backup Camera Install 02-06-2013, 01:46 AM
05BGCrystal Re: Backup Camera Install 02-06-2013, 12:12 PM
REDCRAPGP I would probably hook the... 02-06-2013, 12:31 PM
1LoudGrandPrix Re: Backup Camera Install 02-09-2013, 11:33 AM
jteske88 Re: Backup Camera Install 02-09-2013, 12:17 PM
Harbinger207 Re: Backup Camera Install 07-13-2017, 04:32 AM
JohnRider Re: Backup Camera Install 07-13-2017, 08:37 AM
Harbinger207 Re: Backup Camera Install 07-13-2017, 11:48 PM
BustOutAnothaThou Re: Backup Camera Install 10-13-2017, 12:33 PM
  1. #1 Backup Camera Install
    SE Level Member 05BGCrystal's Avatar
    Jan 2013
    Waterloo, Iowa
    Has anyone here installed backup cameras on their 04+ GPs? I don't want to pay $75 to get a $20 camera installed. I'm good with electronics and I know I could do it... it is simply the matter that it is WINTER in Iowa and I have no garage. (VERY VERY IMPATIENT as well)
    New Waterproof E350 Car Back Up Rear View Day Night Camera NTSC 628x582 Pixel | eBay
    Go for it. It's rather simple verify your headunit has a input for it.
    04 Comp G.
  3. #3 Re: Backup Camera Install
    Omaha, NE
    Quote Originally Posted by 05BGCrystal View Post
    Sounds like this thread was pointless then...
    What are you waiting for?
  4. #4 Re: Backup Camera Install
    Houston
    You don't even need to be good with electronics to install that. And sorry, I cannot help with the winter problem, yet. Hopefully I'll have that solved by next year. Stay tuned.
  5. #5 Re: Backup Camera Install
    Omaha, NE
    I would be in for a group buy on the resolution for a winter problem.
    Oh, nevermind. My shop is heated.
  6. #6 Re: Backup Camera Install
    Houston
    Lol, my state is heated.
    Keith..I edited your post. You said your state was headed...pretty sure you meant heated. lol
    Lol, thanks Bill. It was on purpose. I was following Spades misspelling, but I see he edited it.
  7. #7 Re: Backup Camera Install
    Jan 2013
    Waterloo, Iowa
    Well I just wanted to see what other people's experiences were with the installation and/or camera itself. The head unit is being installed as we speak. So I'll be sure to show give a review on that as well. (Not sure if anyone cares really but I like to look for reviews before I buy.) The head unit does have the camera input so no worries there. I believe I would hook the camera power up through one of the tail lights. (the reverse light of course) and find a separate ground / make one.
    I would probably hook the power up to the headunit as well that way it should always be on whenever the HU is running so you could see behind you even without backing up.
    04 Comp G.
  9. #9 Re: Backup Camera Install
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Don't quite get why you would need one unless you have a walled off car... As for the reverse lights should be fine as long as the camera doesn't take allot of power
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  10. #10 Re: Backup Camera Install
    Yoga city
    typical the cams run of just 12volt very low amperage, in my 97 i had ran my power and turn on off the reverse lamps. its do-able
  11. #11 Re: Backup Camera Install
    Jul 2017
    maine
    how did you run the camera from the rear into the interior
  12. #12 Re: Backup Camera Install
    May 2016
    Lincoln, Nebr
    I ran 2 wires to the back of my car. One wire was the power for the camera, so I could view behind me without being in reverse. The second wire was my trigger wire that was hooked up to the reverse wire. I grounded the camera on a bolt on the trunk lid. I mounted the camera on the bottom side of the reverse light. I actually removed it from the car (really easy), refinished it (cuz it was faded) and mounted it off the car just for easier working space.
  13. #13 Re: Backup Camera Install
    Jul 2017
    maine
    which is the positive wire the brown or green wire
  14. #14 Re: Backup Camera Install
    Sep 2016
    Columbus, Ohio USA
    There is a tool that most auto part stores carry that is not too expensive. It's basically just a simple circuit that when grounded, can light a bulb when applied to wires with current. Just put the parking brake on/Chock the tires, unplug the light bulb, leave the car in the start position (DO NOT START THE CAR) then put the car in reverse. that tool will light up on the correct wire
  1. Backup light blues
    By DRWBRTq19 in forum General Tech Discussion
    Last Post: 04-02-2012, 03:43 PM
  2. With a new camera, comes new pictures.
    By Koniig in forum Off Topic Discussion
    Last Post: 01-18-2011, 01:19 AM
  3. Help Onstar Backup battery
    By rilcoat in forum General Tech Discussion
    Last Post: 07-04-2010, 09:58 AM
  4. electrical help no trunk release, backup lights
    By BIGGRASS in forum General Tech Discussion
    Last Post: 08-03-2009, 06:53 PM
  5. Backup warning system
    By ridgeway417 in forum General Tech Discussion
    Last Post: 02-19-2009, 03:22 PM
