Thread: Backup light blues
Results 1 to 3 of 3
  1. #1 Backup light blues
    SE Level Member DRWBRTq19's Avatar
    Jefferson City MO
    Working on a '98 GP GT, anytime I shift into reverse I blow the backup lamp fuse.
    I was originally thinking short but it has been suggested that it might be a bad ground.
    Does anyone know where this systems ground is?
    And as I'm horrible with electrical problems if anyone has other*opinions/options/suggestions I'm all ears.
    Thanks in advance.
    Drew
  2. #2 Re: Backup light blues
    Ohio
    definitely sounds like a ground..
    check the harness at the lights. i think it should be back there under the trunk matting maybe
  3. #3 Re: Backup light blues
    I live here. TLSheff's Avatar
    Also check the lights and make sure you don't have corrosion building up between the points, if they have anything connect them it can cause a short and the fuse to blow. Just an easy pull the bulbs and inspect the socket check over. Often simple things tend to be the culprit.
  1. After tune up blues
    By Austin2000SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2011, 11:17 PM
  2. Anyone here into the blues?
    By Pairsnpaint in forum Off Topic Discussion
    Last Post: 05-13-2011, 02:28 PM
  3. Help Onstar Backup battery
    By rilcoat in forum General Tech Discussion
    Last Post: 07-04-2010, 09:58 AM
  4. gt blues
    By MARKS99 in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 10:56 AM
  5. Backup warning system
    By ridgeway417 in forum General Tech Discussion
    Last Post: 02-19-2009, 03:22 PM
