Thread: Use monsoon amp wiring for new amp?
Results 1 to 20 of 28
  1. #1 Re: Use monsoon amp wiring for new amp?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by polarissucks View Post
    Is there a chance that the stock wiring won't be enough?
    There is no guess work here. 80W at 3ohms can only max out at 5.1amps of current. Then that means you can use as small as 18ga wire. And that is peak possible amps, not continuous, so you could probably get away with even smaller if you had to.
  2. #2 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Winnipeg
    Thanks.
  3. #3 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Winnipeg
    So I used to factory wiring. I should get no degradation of sound quality from using this?
  1. monsoon rear speaker wiring question...
    By ddw350 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2014, 08:39 PM
  2. 04-08 Monsoon Wiring Diagram?
    By madpat in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2011, 12:34 AM
  3. questions about the monsoon wiring..
    By blowfishRus6 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 06:42 PM
  4. Monsoon wiring diagram?
    By GiAnT4LYFE in forum Audio, Security & Visual Electronics
    Last Post: 04-30-2009, 03:34 PM
  5. wiring diagram for 05 non monsoon
    By 05grndprix in forum Audio, Security & Visual Electronics
    Last Post: 10-07-2008, 02:56 AM
