Thread: Use monsoon amp wiring for new amp?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Use monsoon amp wiring for new amp?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I'm a fan of upgrading the ground. Easiest is the rear strut tower. I happened to have the correct nut on hand. You can take one nut off and put ground on and re-attach. I'm not a fan of the anemic stock wires either, but it's all about what you're trying to do.
  2. #22 Re: Use monsoon amp wiring for new amp?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by polarissucks View Post
    thanks, appreciate it. I will just use the existing wires, was just worried it would degrade sound. Going 80 watts at 3 ohms to the front doors.
    I've got 100W @ 3.6ohm in my doors on the factory wires and they sound much better than stock.
    The rear shock tower is an adequate ground IF it works, but I would sand away the paint under which ever stud you use, because technically the shock mount stud shouldn't be a ground.
  3. #23 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Winnipeg
    Is there a chance that the stock wiring won't be enough?
  4. #24 Re: Use monsoon amp wiring for new amp?
    Oct 2011
    Toledo, OH
    There is no guess work here. 80W at 3ohms can only max out at 5.1amps of current. Then that means you can use as small as 18ga wire. And that is peak possible amps, not continuous, so you could probably get away with even smaller if you had to.
  5. #25 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Winnipeg
    Thanks.
  6. #26 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Raytown, MO
    Haha sorry. Forgot that I ground off the paint under nut...
  7. #27 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Winnipeg
    So I used to factory wiring. I should get no degradation of sound quality from using this?
  8. #28 Re: Use monsoon amp wiring for new amp?
    Oct 2011
    Toledo, OH
    Yep you're good.
  1. monsoon rear speaker wiring question...
    By ddw350 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2014, 08:39 PM
  2. 04-08 Monsoon Wiring Diagram?
    By madpat in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2011, 12:34 AM
  3. questions about the monsoon wiring..
    By blowfishRus6 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 06:42 PM
  4. Monsoon wiring diagram?
    By GiAnT4LYFE in forum Audio, Security & Visual Electronics
    Last Post: 04-30-2009, 03:34 PM
  5. wiring diagram for 05 non monsoon
    By 05grndprix in forum Audio, Security & Visual Electronics
    Last Post: 10-07-2008, 02:56 AM
