Thread: Would this component system work for the rear speakers?
Results 1 to 10 of 10
  1. #1 Re: Would this component system work for the rear speakers?
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Quote Originally Posted by SaukRapids View Post
    1 & 2 seem contradictory.
    Monsoon does not have a "turn-on" wire. The stock amp responds to the audio signal, using that to switch on/off.
    Well, golly. Wrong.
    Pin #6 of connector C3 that goes into the amp is listed as "radio on". Listed as pink for Saturn Sky's and Hummers with Monsoon, is found as Purple in Grand Prix's. My own testing found the 0 volts on the wire with the radio off, and 12 volts with the radio on. The same wire is used to turn on the Sat. antenna in the roof. The same wire that is currently turning the amplifiers on and off in my trunk.
    If you look at the Full Service Manual for '06-'08 Pontiac Grand Prix's, in the electrical section, you can verify this for yourself. As I did. You can even download the FSM as a .PDF from right here on GPForums. Like I did. That way you know you have good information on what you are doing, so you can get 'er done right, and then share that info with other people. Like I did. Not just shoot my loud mouth off in forums. Like you did.
    SO. Yeah. The purple wire going to the Monsoon amp under the deck is the remote turn on wire.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  2. #2 Re: Would this component system work for the rear speakers?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Quote Originally Posted by Gregorius View Post
    Get f*cked. Hows that for shooting my mouth off?
    I pointed out discrepancies and incomplete information, and you jump my sh*t with childishness? Hope that GXP blows the trans, f*ckface.
  3. #3 Re: Would this component system work for the rear speakers?
    Davenport, IA
    Well, cupcake, you are still wrong.
  1. possible work around for bleeding ABS system?
    By Greg84 in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2015, 01:26 PM
  2. Fuel Injection/System Cleaners? Do They Really Work?
    By ThaUnknownOne in forum 5.3L V8 (LS4)
    Last Post: 07-12-2013, 12:16 PM
  3. Will these work for rear deck..?
    By Raviaan in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2012, 11:50 PM
  4. Monsoon System stopped working just tweeters work
    By Shadowz89 in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2011, 08:37 PM
  5. How to modify ZZP Gen I Stage II IC core/plates to work with factory PCV system
    By JEFFSGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2008, 12:53 AM
