Quote Originally Posted by Gregorius View Post
The biggest bummer on these, is that in order to even swap in a code matching Junkyard radio, they need to be "Programmed in" by the Dealer, or someone with a Tech 2. Anti-theft, VIN matching etc.
Yes, pain in the ass. Door chimes, Sat radio, a feed for HUD info all goes thru the stock... bastard of a radio. There are new "rebuilt" radios on ebay, they even come with an Aux in jack on the face-plate <Phone Jams!>. I don't remember if they need programmed in or not. Round 300 bucks though.
Chimes didn't use the radio until later I'm fairly certain. This car being an 01 had them handled separately. 05 I think is when chimes were integrated.
OP: I should clarify, are they the units from the car. If they are scrapyard pulls or used units something could be wrong with the install.
The wire in the DRL circuit sounds like someone wanted 12 Volt when the key was "on." This is often the case with dash cameras or other after market AV accessories.
Interior lights being "always on" screams a short in the system.
I am sorry to be rude, but severe electrical gremlins are on the edge of being outside DIY territory. If you have experience or a friend with experience you can really proceed, but if you are coming in totally blank a shop is recommended. Shorts can go as far as causing fire in the vehicle. Additionally, GM is obnoxious when it comes to swapping many components that are integrated into the system, offend requiring them to be programmed to VIN match the rest of the system or they will not function correctly.
Sent from my ASUS_Z00TD using Tapatalk
