Thread: '01 GTP - Electrical Gremlins [lights] troubleshooting?
Results 1 to 10 of 10
ELECTRICxWIZARDx '01 GTP - Electrical Gremlins... 09-04-2017, 09:34 PM
Gregorius Re: '01 GTP - Electrical... 09-05-2017, 10:26 AM
ELECTRICxWIZARDx Re: '01 GTP - Electrical... 09-06-2017, 12:10 AM
Gregorius Re: '01 GTP - Electrical... 09-07-2017, 11:07 AM
nox Re: '01 GTP - Electrical... 09-08-2017, 11:27 PM
ELECTRICxWIZARDx Re: '01 GTP - Electrical... 09-11-2017, 12:16 AM
nox Re: '01 GTP - Electrical... 09-07-2017, 09:44 AM
ELECTRICxWIZARDx Re: '01 GTP - Electrical... 09-07-2017, 01:27 PM
ELECTRICxWIZARDx Re: '01 GTP - Electrical... 09-07-2017, 01:14 PM
nox Re: '01 GTP - Electrical... 09-11-2017, 01:35 PM
  1. #1 Re: '01 GTP - Electrical Gremlins [lights] troubleshooting?
    GT Level Member Gregorius's Avatar
    Davenport, IA
    My first steps would be to disconnect anything to do with the radio. Then go after the blower motor problem and put it back to the way God <and GM> intended.
    The idea is to undo anything that was done to the stock system, then trouble shoot the original problem. Hopefully you find 1 major problem that is causing many symptoms.
    I find the turn signals flickering the DIC interesting.
    WEAK OLD BATTERY?
    CORRODED GROUND POINT. These cars have.... grounding issues, to put it mildly. Start simple, the battery. Dirty/loose cables, grounds to the frame, to the engine. There are "Harness" ground points for lack of a better term. Under the hood, under the dash, under the carpet. Check for water damage. <flood car?> Wet carpet? The sunroof drains have a tendency to fall off inside the roof and dump water into the pass compartment. Is it all dry in there? Also the AC drain clogs and fills the blower with water then drips out into the passenger front footwell.
    There are a ton of resources on here including all the grounding locations in a PDF somewhere...
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  2. #2 Re: '01 GTP - Electrical Gremlins [lights] troubleshooting?
    SE Level Member ELECTRICxWIZARDx's Avatar
    Sep 2017
    SW Oklahoma
    Awesome, thanks for the tips.
    Question, would I need to track down a stock radio? I've read something to the effect that removing it can screw all kinds of stuff up, and some installs just relocated it to the trunk to make onstar, etc, play nice.
    I don't think it's a bose system, RPO codes on trunk sticker show -
    UP3: AM/FM STEREO, SEEK/SCAN, COMPACT DISC
    UW6: SPEAKER SYST, 6, DUAL F/D TWEET & WOOF, DUAL EXT
    Forgot to mention, keyless entry fob does not work either. Have not ruled out damage to fob itself though.
    I've seen [well, smelled] no obvious signs of water damage. Carpet is not discolored.
    But, tomorrow I'll go by a parts store, have them test the batt & alternator, then progress from there.
  3. #3 Re: '01 GTP - Electrical Gremlins [lights] troubleshooting?
    Davenport, IA
    Quote Originally Posted by ELECTRICxWIZARDx View Post
    The biggest bummer on these, is that in order to even swap in a code matching Junkyard radio, they need to be "Programmed in" by the Dealer, or someone with a Tech 2. Anti-theft, VIN matching etc.
    Yes, pain in the ass. Door chimes, Sat radio, a feed for HUD info all goes thru the stock... bastard of a radio. There are new "rebuilt" radios on ebay, they even come with an Aux in jack on the face-plate <Phone Jams!>. I don't remember if they need programmed in or not. Round 300 bucks though.
  4. #4 Re: '01 GTP - Electrical Gremlins [lights] troubleshooting?
    Aug 2016
    CT/RI Border
    Quote Originally Posted by Gregorius View Post
    Chimes didn't use the radio until later I'm fairly certain. This car being an 01 had them handled separately. 05 I think is when chimes were integrated.
    OP: I should clarify, are they the units from the car. If they are scrapyard pulls or used units something could be wrong with the install.
    The wire in the DRL circuit sounds like someone wanted 12 Volt when the key was "on." This is often the case with dash cameras or other after market AV accessories.
    Interior lights being "always on" screams a short in the system.
    I am sorry to be rude, but severe electrical gremlins are on the edge of being outside DIY territory. If you have experience or a friend with experience you can really proceed, but if you are coming in totally blank a shop is recommended. Shorts can go as far as causing fire in the vehicle. Additionally, GM is obnoxious when it comes to swapping many components that are integrated into the system, offend requiring them to be programmed to VIN match the rest of the system or they will not function correctly.
    Sent from my ASUS_Z00TD using Tapatalk
  5. #5 Re: '01 GTP - Electrical Gremlins [lights] troubleshooting?
    Sep 2017
    SW Oklahoma
    @nox - what units are you asking about? I'm confused.
    No offense taken, I'm starting to lean towards letting my usual mechanic take a look at it. I'm far handier with a wrench than a multimeter, but do have a grasp on basic electronic repair, due to learning to solder to fix (or mod wiring scheme) guitars/basses. Diagnosis is where my skills lack. Gut tells me it's gonna end up being the BCM though.
    Main troubles as of right now is the lack of interior lighting, fog lights, and blower motor running with key off. All of which, just minor inconveniences. I bought this as a second car anyway, to have something more fun, comfortable, and better mpg's than the truck. ['92 1/2 ton Chevy SWB.] Knew it would need some sorting out going into the purchase.
    Everything appears stock, except audio system. There were left-over wires [remote on, ground, rca] to the trunk for subs, which i have now removed.
    Oh! I followed the extra "mystery" wire from the DRL fuse the other day. Interior fusebox--> Door Jamb-->Under Hood --> is spliced into the wiring for the passenger side turn signal bulb. It's soldered into [i think the brown wire, iirc.] When I unplugged from fusebox and turned key back on, something in the dash started making a constant solenoid click, like a bad starter but not as loud. Couldn't pinpoint source, but definitely driver's side. Thinking back, possibly ignition related? Did not function check outside lights w/o wire.
    At this point, i threw in the towel. Plugged the mystery wire back in, and decided to just leave it the heck alone for now. Switched focus to restoring the headlight lenses and a full int/ext detail.
    Edit to add: forgot to mention, TCS OFF button and low trac DIC lights do not function either. Hazard flasher switch and shift-lockout-something are missing as well. Keyless entry does not work either, but have not ruled out fob as problem.
  1. Electrical gremlins with headlights and blower motor, please help?
    By Jcinstalls in forum General Tech Discussion
    Last Post: 05-01-2013, 02:04 AM
  2. Electrical issue - interior lights
    By JoeBlood in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2012, 07:01 PM
  3. Electrical gremlins
    By nos4blood70 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2012, 09:14 AM
  4. Need help with some electrical gremlins
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2012, 11:10 AM
  5. electrical help no trunk release, backup lights
    By BIGGRASS in forum General Tech Discussion
    Last Post: 08-03-2009, 06:53 PM
