Thread: Can't remove key without using the manual release
Results 1 to 4 of 4
  1. #1 Re: Can't remove key without using the manual release
    under the column is a pop off button, you push a pencil or the likes up inside to free the key, that part is likely bad. you can roll up a business card or use a fat straw and cut it to length so it pushes the release button with the cap back on.
    directions for opening the column are in this link http://sparkys-answers.com/2009/09/2...-changing.html iirc the part is in the pics there too.
  2. #2 Re: Can't remove key without using the manual release
    Mar 2016
    Philadelphia
    Thx I can get it out manually by pushing the solenoid as you pointed out, I'm looking for a permanent fix, thx.
  1. Zip Tie Key Release Button
    By SubwayGuy in forum General Grand Prix Discussion
    Last Post: 04-19-2015, 06:33 PM
  2. Trunk release
    By Goy in forum Introductions/Noob Questions
    Last Post: 01-07-2013, 01:45 PM
  3. Key release
    By Jay7199 in forum General Tech Discussion
    Last Post: 06-16-2011, 12:28 PM
  4. GTP-trunk release
    By PCTGTP in forum General Tech Discussion
    Last Post: 05-19-2010, 03:55 PM
