Thread: How Can I Switch Out My BOSE System 4 My New Stuff
Results 1 to 13 of 13
thagizzle213 How Can I Switch Out My BOSE... 02-07-2009, 03:34 PM
flynn Re: How Can I Switch Out My... 02-07-2009, 03:45 PM
SyntheticShield Re: How Can I Switch Out My... 02-07-2009, 04:32 PM
Slueth66 Re: How Can I Switch Out My... 02-07-2009, 06:18 PM
Blown97 Re: How Can I Switch Out My... 02-07-2009, 06:28 PM
The Guz Re: How Can I Switch Out My... 02-07-2009, 07:53 PM
Slueth66 Re: How Can I Switch Out My... 02-15-2009, 10:04 PM
GeddyLee Re: How Can I Switch Out My... 02-17-2009, 11:20 AM
Slueth66 Re: How Can I Switch Out My... 02-17-2009, 11:20 PM
GeddyLee Re: How Can I Switch Out My... 02-18-2009, 02:24 AM
Slueth66 Re: How Can I Switch Out My... 02-18-2009, 09:49 AM
GeddyLee Re: How Can I Switch Out My... 02-18-2009, 11:11 AM
GeddyLee Re: How Can I Switch Out My... 02-18-2009, 02:21 AM
  1. #1 Re: How Can I Switch Out My BOSE System 4 My New Stuff
    St. Louis Mo.
    Quote Originally Posted by Slueth66 View Post
    I replaced all speakers so my 4 inch in the back would be useless. Should i just run those off the bose amp and the other 4 off the dead unit?
    I had thought about doing just that as well, but I nixed the idea cause the stock 4" mid ranges suck. I upgraded them to Infinity Reference 4" speakers, but wound up dumping the whole set for a set of Memphis MClass 6x9's. I think eventually I will add some more 4" speakers, but at the moment its not really important.
    Its a judgement call really
    James Shafer
    St. Louis MO
  2. #2 Re: How Can I Switch Out My BOSE System 4 My New Stuff
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    So your saying if i want to run new wire, just run the new wire and leave the stock wiring in place? ill probably have this car till it dies
  3. #3 Re: How Can I Switch Out My BOSE System 4 My New Stuff
    St. Louis Mo.
    Well that is up to you. Like I said, its a matter of choice really, the stock wiring is tucked out of the way so its not really cluttering anything up and you can zip tie the aftermarket wiring to the factory speaker if you want to give it a cleaner look too.
    As for the wiring, I would recommend using a good brand of wire, and perferably something in the 12ga line if you plan on getting any high end Amps for your car.
    I am currently running RockFord Fosgate wiring, but I am looking to switch over to Monster Wire when the weather starts to stay warmer.
    James Shafer
    St. Louis MO
  1. bypassing Bose amp
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-04-2009, 11:51 PM
  2. bose removal
    Last Post: 12-02-2008, 01:20 PM
  3. Bose?
    By flynn in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2008, 04:24 PM
  4. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
