Thread: Aftermarket HU not outputting sound
Results 1 to 10 of 10
  1. #1 Aftermarket HU not outputting sound
    May 2017
    Minnesota
    Hey all,
    I installed a Sony GT56UI headend into my car around a year and a half ago with a harness and it worked great, however since recently it sometimes it never outputted any sound during the day however it would work in the morning, now it never works at all. The car is a 02 Grand Prix GT with the Bose system; would appreciate any advice to help narrow down the issue
  2. #2 Re: Aftermarket HU not outputting sound
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    It works in the morning when cold, but maybe not when warm?
    Could be the deck. Do you have another one to try?
    Edit: If you have Monsoon/Bose, the old amps go out.
  3. #3 Re: Aftermarket HU not outputting sound
    May 2017
    Minnesota
    Tested with my factory radio and there is no sound; any way i can test if it's the amp? it's the bose system
    EDIT: It used to work when cold, but now it doesn't at all
  4. #4 Re: Aftermarket HU not outputting sound
    Aug 2016
    CT/RI Border
    Bose amp is located in or under the glove box iirc. The symptoms you describe line up with a dead amp.
    Sent from my ASUS_Z00TD using Tapatalk
  5. #5 Re: Aftermarket HU not outputting sound
    SE Level Member 1FastGP's Avatar
    May 2015
    Indian Trail, NC
    Bose amp is in the trunk slightly offset to the left under the rear deck where the speakers are
    Sent from my SM-G900V using Tapatalk
  6. #6 Re: Aftermarket HU not outputting sound
    GTP Level Member simbah's Avatar
    Lala land
    Quote Originally Posted by 1FastGP View Post
    That would be a Monsoon amp for 04-08. OP is talking about a Bose system in earlier models and that amp is located behind the glove box. However I could be wrong about the Bose amp, never had one.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  7. #7 Re: Aftermarket HU not outputting sound
    May 2015
    Indian Trail, NC
    97-98 delco 8 speaker was behind glovebox 99+ bose was in the trunk I've had cars with both
  8. #8 Re: Aftermarket HU not outputting sound
    Lala land
    Sorry my bad.
  9. #9 Re: Aftermarket HU not outputting sound
    May 2017
    Minnesota
    Took out the bose amp, the capacitors don't appear blown, however there is a decent amount of corrosion on the heatsink; the door chimes work also which is weird; are they not connected to the amp?
  10. #10 Re: Aftermarket HU not outputting sound
    May 2015
    Indian Trail, NC
    Door chimes through the amp was an 04+ thing
  1. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  2. new sound:)
    By beckys2000gt in forum General Tech Discussion
    Last Post: 07-03-2010, 06:19 PM
  3. This sound right?
    By BwolfGT in forum General Tech Discussion
    Last Post: 09-28-2009, 12:29 AM
  4. sound
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2009, 11:00 PM
  5. S/C Sound
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 11-18-2008, 10:33 PM
