Hi,
I installed a new Head Unit in my 2006 Pontiac Grand Prix (a Sony WX-900BT), and used the proper adapter, the PAC RP5-GM11. Everything is working great except for the steering wheel controls. I set the radio select switch on the adapter to 8 (the correct setting for sony), then connected everything and plugged in the 3.5mm SWC cable into the SWC jack on the back of the head unit. When I press my SWC buttons, the programming light blinks, indicating that the adapter is receiving input from my steering wheel controls; however, my head unit will not recognize that any buttons are being pushed!
I have even tried reprogramming the adapter as per instructions in its manual, and I have attempted to register buttons using the SWC registration protocols in the head unit (which always just timeout because the HU doesn't register any input).
Does anyone have any idea what to do?
Thank you
