Thread: bypassing Bose amp
Results 1 to 6 of 6
  1. #1 bypassing Bose amp
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    Is there any way to bypass the bose amp in a 2001 grand prix? Or do i have to run new speaker cables to all 6 of the speakers? Im installing a new head unit and want to run the speakers off the head unit
  2. #2 Re: bypassing Bose amp
    No real way of just bypassing it "easily." Is the amp blown or do you just want to bypass it?
    brandon
  3. #3 Re: bypassing Bose amp
    Nov 2008
    Iowa
    Well i dont think the sound quality is the best from the bose system and im not sure if it will improve if a headunit is installed and i keep the bose amp. im leaning towards powering my speakers off the head unit or a different amp.
  4. #4 Re: bypassing Bose amp
    adding the deck will help but your weak link is the stock speakers, replacing the fronts with some nice aftermarkets will make a world of difference. I'm running some infinities on the same system and they scream over the subs in the trunk.
    brandon
  5. #5 Re: bypassing Bose amp
    Nov 2008
    Iowa
    im thinking about running it off the stock amp until i decide to by a new amp and who knows maybe it will sound better so i wont need to. i got all the speakers replaced except the front with infinities so my next step will be new head unit and putting in some new fronts im thinking about modifying for 6 1/2's instead of 5 1/4's. =)
  6. #6 Re: bypassing Bose amp
    you prolly should have done the fronts first becasue that's what you hear most, i run the kappa's and they sound really good
    brandon
  1. bose removal
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 01:20 PM
  2. Bose stereo problem
    By jiggar1964 in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2008, 05:02 PM
  3. BOSE with a mind of its own....
    By armcclure in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2008, 02:52 PM
  4. Bose?
    By flynn in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2008, 04:24 PM
  5. belt help, bypassing power steering pump
    By skates in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2008, 11:24 AM
