Thread: LED resistor help
Results 1 to 17 of 17
  1. #1 LED resistor help
    SE Level Member BluFlameGTP's Avatar
    Nov 2008
    Duluth, MN
    I'm going to attempt Abrasive's lighted cupholder mod, but use the color changing LEDs.
    I know i can wire it up just fine, the only thing i'm having trouble with is figuring out which resistor i need, since each color needs different power voltage.
    I've used the resistor calculators and stuff, but still can't figure it out.
    Here's the link to the specs page
    Auto Color Changing LED specs
    Thanks a lot for the help guys.
  2. #2 Re: LED resistor help
    GTP Level Member Scimmia's Avatar
    QCA, IA
    From what I can see, this isn't a standard LED that you can just use a current limiting resistor on. It's got electronics in it that control the voltage to the LED itself, you need to supply it with a constant 4.5V.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: LED resistor help
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Each color LED is built different something to do with a gap of the material on the chip in the led the decides the color
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: LED resistor help
    Nov 2008
    Duluth, MN
    So all i would need to do is to wire it into to say... the constant 12v cigarette lighter plug (using a switch) and that should be all it needs? NO resistors right?
  5. #5 Re: LED resistor help
    QCA, IA
    Quote Originally Posted by BluFlameGTP View Post
    Quote Originally Posted by Scimmia View Post
    12V will fry that thing.
    Datasheet: http://www.superbrightleds.com/pdfs/RL5-RGB-ACC.pdf
  6. #6 Re: LED resistor help
    Nov 2008
    Duluth, MN
    alright... so i need a resistor that will bring it down to 4.5V.
    Does anyone know off the top of their head what size resistor would do that?
  7. #7 Re: LED resistor help
    QCA, IA
    No. Forget all about resistors, they aren't going to help you in this case. A resistor is reactive, and this thing could draw varying amounts of current. Your best bet is to use a voltage regulator like an LM317. Although a zener diode with a resistor could work, the LM317 is a much better option.
  8. #8 Re: LED resistor help
    Nov 2008
    Duluth, MN
    Alright, i get it. I've never used anything like the LM317, and am kinda confused on how i'd wire it up.
    I'm trying to read up on it right now.
  9. #9 Re: LED resistor help
    Nov 2008
    Duluth, MN
    Alright, i'm stumped. I have no idea. If no one can help, maybe ill just take the easy way and just follow the sticky....
  10. #10 Re: LED resistor help
    QCA, IA
    1 LM317 + .1 uf cap (ceramic) + 25 uf cap (electrolytic, value not really that critical) + 240 ohm resistor + 620 ohm resistor = 4.48V power supply.
    A 10 uf tant cap on the adj rail could be good, but I doubt it would make much difference in this application. Heck, you could probably eliminate the caps all together and be fine.
  11. #11 Re: LED resistor help
    GT Level Member BackInBlack's Avatar
    Vermont
    See my web site.
    The GPs are long gone...
  12. #12 Re: LED resistor help
    QCA, IA
    Quote Originally Posted by BackInBlack View Post
    See my web site.
    I took a look at your site, I don't see anything that will help. Link?
  13. #13 Re: LED resistor help
    i would say a 510 ohm resistor +/- 5%, if it's auto changing that means auto changing, you shouldn't have to change the input voltage.
    brandon
  14. #14 Re: LED resistor help
    Odessa, MO
    I would just save yourself the trouble and buy the LW-RGB Wired RGB LED's from Superbright. They have the resistor built in so you wouldn't even have to worry about it. This was my original plan when I was thinking of using the color changing ones. I was just going to take off the screw on nut part on the top and stick the threaded housing of the LED through the holes in the cupholder so they were flush with the bottom.
    Third item from the bottom of the page....
    Super Bright LEDs - Car Accents
    Specs on them....
    http://www.superbrightleds.com/specs/LW-RGB.htm
  15. #15 Re: LED resistor help
    Nov 2008
    Duluth, MN
    Thanks a lot guys, i really appreciate the kind of help that's given here. Thanks to everyone that pitched in advice.
    I think i'm going to go with the LEDs that Abrasive just informed me of. I looked through that exact page and never saw those, thanks for the link.
    Do you think the LED has enough "extra" on the top that i could just sand it down flush with the threads?
  16. #16 Re: LED resistor help
    if you cut it from the bottom you might be able to bevel the hole so you don't have to sand it down, not sure how thick it is though, just a thought
  17. #17 Re: LED resistor help
    Nov 2008
    Duluth, MN
    That's also a thought that ran through my head. I just want as much surface area from the LED showing as possible so that it doesn't focus the light too bad...
  1. Blower Motor Resistor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 09-29-2017, 04:39 PM
  2. Blower Motor Resistor
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 02-28-2014, 05:34 PM
  3. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  4. replaced new blower resistor and still no heat
    By nemesis in forum General Tech Discussion
    Last Post: 11-02-2008, 12:29 AM
  5. The Old and The New, Blower Motor Resistor
    Last Post: 01-29-2008, 12:31 PM
