Thread: Installed Locx (rca converter) and now sub cuts out
Results 1 to 5 of 5
  1. #1 Installed Locx (rca converter) and now sub cuts out
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    In installed the soungate locx and now I have a few problems.
    Now the gains are all messed up. The sub will cut out when turned to loud. Obviously this sounds like a gain issue. When I turn down the gain it obviously does not hit as hard, but it still cuts out.
    This mostly happens when the HU is turned near max. It will even cut out on songs that have little to no bass. It NEVER did this with the high pass. The sub hit very hard without hessitation with the high pass running through one channel.
    I have tried messing with the gains for over two hours. Not luck. Right now it does hit but not nearly at its full potential.
    What do you think I should do? The connections are soldered to the left and right stock sub connections.
    Im in a pickle and I am considering going back to the high pass. Thanks for the help!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: Installed Locx (rca converter) and now sub cuts out
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    Get an aftermarket head unit. Those LOCX things are junk and are only rated for 85w per channel. It's proably overheating and malfunctioning
    2008 Grand Prix + Kenwood KVT815DVD, Kicker SXRC Controller, Kicker SX 1250.1, Kicker (2) 12" L7's, Kicker SX 900.4, Kicker RS65.2 Components in front. Infinity Refs 9623i 6X9's in rear
  3. #3 Re: Installed Locx (rca converter) and now sub cuts out
    Bartlett, IL
    damn... i think ur right. time to sell it on ebay as "used"
    How To: E-Brake Pwn
  4. #4 Re: Installed Locx (rca converter) and now sub cuts out
    SE Level Member MyPrixGT06's Avatar
    Weirton, WV
    Defiantly an amp overheating problem! Your amp is over working to push your speakers and has a safety feature to make sure you don't blow your amp. continuing to run it like this will break your amp. Either get a bigger amp or don't turn it up so loud.
  5. #5 Re: Installed Locx (rca converter) and now sub cuts out
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    The last post was January of 2009.... LOL
  1. OPEC Cuts Production, Prices Fall Anyway
    Last Post: 12-18-2008, 10:55 PM
  2. @115 Engine Cuts out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-23-2008, 09:51 AM
