Thread: help with amp and speakers
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 help with amp and speakers
    Oct 2015
    gwinn mi
    I have a 04 GP with stock radio aftermarket rear speakers amp and subs. how can i get them to work with the stock radio. or can i.
  2. #2 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Use a high to low level converter, it takes in speaker level outputs and steps them down to line level. As far as the turn on I was looking at that last night. I have a diagram for the 05' and it has speaker level and amp level outputs.
    Jeff
  3. #3 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    I have power to the amp but nothing going to the subs
  4. #4 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Need a better explanation, I can interpert that 4 ways.
    Jeff
  5. #5 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    The new amp is shot
    Sent from my HUAWEI H892L using Tapatalk
  6. #6 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    OK, I am not a dentist so I am not going to sit here and pull teeth to get information.
    1 You state that you have aftermarket rear speakers, subs and amp.
    Problem: You don't state what's hooked to where, nothing
    Problem: Your new amp is "shot"
    Now based on the little information you have given, I can't tell you the amp is shot. I can tell you that I have had literately dozens of people come to me to tell me their amp is shot only to find they had the box sliding around in the trunk and the remote turn on wire, one of the power wires, or it slid into something and broke the RCS's or damaged/knocked out the fuse.
    Need Moar info, is I think what the kids say.
    Jeff
  7. #7 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    When I go the car the person that had it before me had it professional installed. The amp that was in it. Was bad because it keep blowing fuses. The amp I put in would not run the sub or the rear Speakers. I know its not the subs I hooked them to my home radio. They work. The have rca cable running from amp to rear deck speakers.
  8. #8 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    What about your remote turn on and power wire fuse for the amp up front by the battery? What amp did you have and what amp do you have now. Model numbers please? Also typically RCA's are not connected to speaker level outputs (your rear speakers). If your old amp had line level inputs and the new amp doesn't then that's not correct. You would need a high to low level converter.
    Jeff
  9. #9 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    The remote turn on is hooked to the radio fuse. the one for the battery is a 50 amp fuse. The amp that was in it is XA-800I. The one that is now in it is autotek ATA800.2
  10. #10 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Does the light come on? what about eh protection light?
  11. #11 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    Its a green light
  12. #12 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Do you have the RCA's connected to the line out?....Go look.
  13. #13 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    Line in
  14. #14 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Tell me more about how you have the RCA's connected to the amp via the 6X9's
    Jeff
  15. #15 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    Can I put pics on here that might help
  16. #16 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    That would be great.
  17. #17 Re: help with amp and speakers
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    Upload your pictures to Photobucket then post the IMG link.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  18. #18 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Another question I have is how do you have the amp connected to the speakers and what is their impedance, are they dual or single voice coil. If the previous amp failed then perhaps it was driving a load that is to low. Your amp is only 2 Ohm stable and if you are driving it bridged into both speakers and they are not 8 ohms then that amp will fail as well.
    Jeff
  19. #19 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    http://s1382.photobucket.com/user/Ra...tml?sort=3&o=2
  20. #20 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    Tell me if there is 3 photos there
  1. Blow speakers in my 03 with Bose speakers, replacement options?
    By Fahrenheit in forum Audio, Security & Visual Electronics
    Last Post: 10-29-2015, 12:08 PM
  2. pioneer ts G1642R speakers into front doors speakers?
    By thomasd2010 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2013, 10:16 AM
  3. Need New Speakers
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 12:29 PM
