Thread: help with amp and speakers
Results 21 to 40 of 46
  1. #21 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Ok break out the instruction manual for your amp.
    Disconnect that converter, you don't need it.
    The plug next to the RCA's is for you to connect the speaker outputs directly to the amp.
    Read the instructions and follow what it says.
    Jeff
  2. #22 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    OK thank you very much
    Sent from my HUAWEI H892L using Tapatalk
  3. #23 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    No problem and once you get it connected and working right, mount that thing correctly.
  4. #24 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    What is a converter is it that small clear box
  5. #25 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    I going to mount it to the back of the amp box
  6. #26 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by raelayotte View Post
    It's a speaker level to RCA level converter, Sometimes they have to have a ground or something else connected to make them work correctly. You already have one built into the amp, it's there for you to use.
    Jeff
  7. #27 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    sorry read that wrong i will unplug the wires next to the rca.
  8. #28 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    No,
    Unplug the RCA's from the amp, remove the clear line converter use the red and black from the right and left sides and connect those wires to the plug next to the RCA's. On this installation you will not use the RCA's at all.
    Jeff
  9. #29 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    Under stand thank u
  10. #30 Re: help with amp and speakers
    GTP Level Member simbah's Avatar
    Lala land
    One quick question. Are you running from speakers to line input? Or is the line input coming from the radio?
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  11. #31 Re: help with amp and speakers
    Lala land
  12. #32 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Look a page up and you will see he has a line level converter going from the rear speakers, then the line level converter goes RCA into his amp.
  13. #33 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Dude start at the beginning instead of jumping all to the end.
    Jeff
  14. #34 Re: help with amp and speakers
    Lala land
    Well then there is the problem. Speakers to amp line in and amp speaker out to subs. What doesn't make sense here? There is no audio signal from speaker. Audio signal comes from radio. I know this is basic stuff but if OP has no idea how it works then they are going to have problems. That is why I posted a basic wiring diagram.
  15. #35 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    You are not getting it. He posted pics and if you don't know that there is audio at the speaker then you don't understand how audio works. Using a Hi to low level adapter to adapt speaker level signal to a lower RCA level signal has been done since probably before you were born. I know some of the first stereos I installed in the 80's I used them. You are only confusing the situation. The only way you could be correct is if the OP has the fader all the way forward. Besides he has line level inputs on the amp there is no reason to use a second one. It will clean up the mess of wiring he has anyway.
    Jeff
  16. #36 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    Its the stock radio
  17. #37 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    I have the rear deck speaker hooked to the high level input
  18. #38 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    everything is working but i sure the subs are bad
  19. #39 Re: help with amp and speakers
    GXP Level Member
    Mar 2015
    Tomball
    Explain since you already said that the subs are good, because you hooked them up inside. Take a better picture of your settings for the amp where the low pass filter, gain and all that is.
  20. #40 Re: help with amp and speakers
    Oct 2015
    gwinn mi
    Ok
  1. Blow speakers in my 03 with Bose speakers, replacement options?
    By Fahrenheit in forum Audio, Security & Visual Electronics
    Last Post: 10-29-2015, 12:08 PM
  2. pioneer ts G1642R speakers into front doors speakers?
    By thomasd2010 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2013, 10:16 AM
  3. Need New Speakers
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 12:29 PM
