Thread: Aftermarket DVD install
Results 1 to 3 of 3
gambler87 Aftermarket DVD install 10-19-2015, 06:22 PM
industrialfish Re: Aftermarket DVD install 10-20-2015, 06:31 AM
FordMan77 Re: Aftermarket DVD install 10-20-2015, 01:25 PM
  1. #1 Aftermarket DVD install
    Dec 2013
    laporte mn
    Ok I got the entire kit to install my flip dvd player into my 04 comp g. There are a couple things I need help with
    First off I will be installing aftermarket speakers in the doors and in the rear. Do I still need to use the factory amplified plug in? I have factory 6 disc CD player with monsoon system and OnStar.
    Second thing, my DVD player has to see power-ground-power to watch movies. Can I use the traction control button to act as a toggle switch to do this sequence?
    Third question. I took my front door panels off the other day to do my interior color change. The stock speakers are in a housing, how did u guys bolt ur aftermarket speakers into those housings? I don't have shallow mount speakers so I don't think the speakers would work when the window is rolled all the way down if I deleted the factory housings.
  2. #2 Re: Aftermarket DVD install
    Oct 2011
    Toledo, OH
    No on the switch as it is a momentary switch, doesn't maintain connection when you release it.
    7"
  3. #3 Re: Aftermarket DVD install
    St. Louis
    To try and answer your third question, take a look at this thread and maybe it will help--> http://www.grandprixforums.net/threa...-in-Grand-prix
  1. aftermarket radio install
    By dpmeeks in forum Audio, Security & Visual Electronics
    Last Post: 08-05-2015, 03:24 PM
  2. 2004 GT Aftermarket Radio Install
    By jmalouin7 in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2014, 12:22 PM
  3. I am looking to install an aftermarket HU...just some questions.
    By 08GPguy in forum Audio, Security & Visual Electronics
    Last Post: 06-01-2012, 09:22 PM
  4. DIC not working after aftermarket radio install
    By rage03usa in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2011, 10:39 PM
  5. questions regarding aftermarket install
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2011, 07:22 AM
