Why'd he swap heads?
On these cars, when you do a cam swap you have to delete DOD which requires the removal of the cylinder heads to pull out the lifters. In order to reduce down-time when I do these packages, I supply a set of freshly cleaned, pressure checked and resurfaced 243 cylinder heads with new seals and BTR spring kit installed on a "core" basis.
