Thread: Some modding questions
Results 1 to 20 of 20
  1. #1 Some modding questions
    SE Level Member Dropped GP GT's Avatar
    Dec 2008
    Wyoming, MI
    I have a 2006 GP GXP and am just starting to mod some. The budget is really tight so only starting with the little things. I'm gonna make a CAI, do a 180 tstat and ngk tr6ix spark plugs. I'm trying to figure out what to mod to get as much power out of this as i can. I already did a shift kit and tranny cooler, was the first things I did, lol. Like i said my budget is tight right now and not gonna do to much. Am I gonna be fine with those mods and not a tune or am i gonna have problems?
  2. #2 Re: Some modding questions
    your fine, as those are not really mods. being a 06 you got one place that tunes that year and up. that would overkill. they are a vendor here. you see the banners up top the page.
  3. #3 Re: Some modding questions
    Skip the thermostat, it will still run at 194º regardless.
    And he has a GXP, HP Tuners supports all V8's from 05-08. I think even EFI live can tune them.
  4. #4 Re: Some modding questions
    tricked by the v8 again. more and more of them creeping in.
  5. #5 Re: Some modding questions
    GXP means V8 Scott
  6. #6 Re: Some modding questions
    who reads?
  7. #7 Re: Some modding questions
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    One of my intakes with MAF upgrade, tune and a ZZP downpipe will comfortably get you 25-30 wheel horsepower. http://www.getoverkilled.ca/ls4.html
    180* stat is highly optional, stock is 187. Modding the stock airbox is better than building an intake on the stock tune. Remove the rear O2 pinch if you can't do a full downpipe, its as bad as the 97-03 Ubend. Fresh plugs and wires are always a good idea.
    Email all inquiries to willoverkill@gmail.com!
  8. #8 Re: Some modding questions
    Dec 2008
    Wyoming, MI
    Thanks for the replies guys, you're awesome
  9. #9 Re: Some modding questions
    Don't even think about forgetting a shift kit and a Trans cooler in there too.
    Very much needed.
  10. #10 Re: Some modding questions
    Don't even forget about reading first guy.
    Thats the first thing he did.
  11. #11 Re: Some modding questions
    Arizona
    You'll want the tune beyond all and catch cans.. best thing you can do for a ls motor
  12. #12 Re: Some modding questions
    Good thing I care.
  13. #13 Re: Some modding questions
    Dec 2008
    Wyoming, MI
    So just skip the tstat then? You guys are awesome. Thanks for the information, i greatly appreciate it, feel free to send more, lol
  14. #14 Re: Some modding questions
    Arizona
    Yea the thermostat is a lot less important than in the 3800 game. Having a all aluminum motor with efficient heads helps out a lot. your stocker opens up at 187 and the fans kick in at 192 regardless. Unless you have a custom operating system via hp tuners or efi live.
    Edit: also go for the ms plug wires there odone of the best. Also the stock air box is trash even if you mod it it still a turd. Make a intake preferably a FWi
  15. #15 Re: Some modding questions
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    For a handheld you could get a diablo intune. Just watch your ft's. After I uploaded there "91oct no dod" the fuel trims were always 10 points lean. I had to change the injector slope to correct. (not a great fix, idle is always 10 points rich)
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  16. #16 Re: Some modding questions
    Arizona
    you don't modify the injector slope on LS vehicles for that very same reason. if you're off on fueling below 3500 rpm then you have to go back and figure out if it was your ve map that is off or your maf Is off. assuming either was spot on from the factory is never the case. This is why I highly recommend a a good tuner or a learning to do it youreself
  17. #17 Re: Some modding questions
    Jan 2013
    Edmonton, Alberta
    ^^ I agree, for some ppl that tune would be enough. I am not happy considering the price of a intune vs hpt. It was the first and last "can tune" I have bought. I will say the tranny does work better now.
    With hpt there would be a learning curve, but I don't think it would be too overwhelming.
  18. #18 Re: Some modding questions
    GT Level Member Bogers04SS's Avatar
    Feb 2010
    Mocksville, N.C.
    Quote Originally Posted by Dropped GP GT View Post
    If you go the Diablo Intune Route, Definitely go with a LEW tune. Lewis does a great job as long as you data log correctly. You can always port your stock intake manifold if you have a dremel tool and polish and port your throttle body as well, if your mechanically inclined. Just make sure you do a little at a time and don't over do it, or you could see a loss in power and erratic idle. These are things you can do on a budget and make power without dropping a ton of money and make the feel of the car overall better. Shift kit as Blue said is a must for these cars! There is a sticky somewhere on how to make your own if your wallet is tight, and it works pretty good for what it is.
    Not much money dropped, Looks good and a noticeable performance increase..... on a budget
    04 Impala SS -- SOLD
    08 Prix GXP -- FWI, 3in DP, TR6IX plugs, Ported & polished throttle body, ported intake manifold, DiabLEW Tuned, wrapped crossover pipe, Cat delete, Factory res., Muffler delete, Poly motor mounts, shift kit, LED bulbs in just about every Da*n thing, ect..
  19. #19 Re: Some modding questions
    Dec 2008
    Wyoming, MI
    That looks beautiful. Nice work, will definately look into this
  20. #20 Re: Some modding questions
    Arizona
    I would never paint coils though they need vent every last ounce of heat possible
  1. Modding Questions
    By prixman in forum Introductions/Noob Questions
    Last Post: 06-01-2013, 04:16 AM
  2. Modding Questions
    By ms3206 in forum General Grand Prix Discussion
    Last Post: 04-16-2013, 10:21 AM
  3. Need help on modding
    By Dj drek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2013, 12:59 PM
  4. Modding 08 GP GT..
    By 08GrandPrixV6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2009, 09:57 PM
  5. modding my gtp
    By scottys99gtp in forum Off Topic Discussion
    Last Post: 02-25-2009, 04:48 PM
