you don't modify the injector slope on LS vehicles for that very same reason. if you're off on fueling below 3500 rpm then you have to go back and figure out if it was your ve map that is off or your maf Is off. assuming either was spot on from the factory is never the case. This is why I highly recommend a a good tuner or a learning to do it youreself
