What type of hose to you all use to replace that rubber hose between the tank and power steering pump. I replaced my power steering pump and used heater hose and I am worried it will split. Any help would be great.
Thanks,
Anthony
Thanks,
Anthony
They sell universal power steering hose at Autozone and oriellys. Heater hose will probably split
Does anyone know the diameter of the hose 3/8
if the end just broke off where it clamps to the pump trim it off and re fit it.
its a return line, so theres no pressure in it too.
not sure if that rubber line comes off the metal part of the line. if it dont, you'll need to cut the line, and fit new hose it it, or use a metal tube and splice the broken line to the new line.
I replaced the high pressure line with heater hose when I replaced my power steering pump. I just want to put the pressure line back before I have an issue.
Hey All just wanted to let you all know that it is 5/8 high temp oil line. Thanks all.
I could see the high temp business, sitting right next to the front cover, and the belt as well.
Silly aluminum things.
