Thread: Power steering rubber line between tank and punp
Results 1 to 9 of 9
  1. #1 Power steering rubber line between tank and punp
    Jun 2012
    Colonia, NJ
    What type of hose to you all use to replace that rubber hose between the tank and power steering pump. I replaced my power steering pump and used heater hose and I am worried it will split. Any help would be great.
    Thanks,
    Anthony
  2. #2 Re: Power steering rubber line between tank and punp
    Arizona
    They sell universal power steering hose at Autozone and oriellys. Heater hose will probably split
  3. #3 Re: Power steering rubber line between tank and punp
    Jun 2012
    Colonia, NJ
    Does anyone know the diameter of the hose 3/8
  4. #4 Re: Power steering rubber line between tank and punp
    if the end just broke off where it clamps to the pump trim it off and re fit it.
    its a return line, so theres no pressure in it too.
    not sure if that rubber line comes off the metal part of the line. if it dont, you'll need to cut the line, and fit new hose it it, or use a metal tube and splice the broken line to the new line.
  5. #5 Re: Power steering rubber line between tank and punp
    Jun 2012
    Colonia, NJ
    I replaced the high pressure line with heater hose when I replaced my power steering pump. I just want to put the pressure line back before I have an issue.
  6. #6 Re: Power steering rubber line between tank and punp
    you could use a compression fitting to re connect the cut line. or add new line with 2 compression fittings.
    or rent or buy a flair tool and add line that way.
  7. #7 Re: Power steering rubber line between tank and punp
    compression fitting on brake line.
  8. #8 Re: Power steering rubber line between tank and punp
    Jun 2012
    Colonia, NJ
    Hey All just wanted to let you all know that it is 5/8 high temp oil line. Thanks all.
  9. #9 Re: Power steering rubber line between tank and punp
    I could see the high temp business, sitting right next to the front cover, and the belt as well.
    Silly aluminum things.
  1. help! installing power steering return line
    By codyAK in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 09:43 PM
  2. Power steering line routing
    By huttler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2013, 05:39 PM
  3. Power-Steering Line Replacement
    By quickster in forum General Tech Discussion
    Last Post: 12-09-2012, 09:37 AM
  4. Power steering line problems NEED HELP
    By supermat690 in forum Introductions/Noob Questions
    Last Post: 10-22-2010, 09:10 PM
  5. Booger I broke Power Steering line
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 10:08 AM
