Thread: O2 Sensor - Bank 1 Sensor 2
Results 1 to 20 of 22
  1. #1 O2 Sensor - Bank 1 Sensor 2
    Apr 2014
    Sioux Falls, SD
    I am getting a code for a bad 02 sensor. Is the bank 1 sensor 2 on the rear manifold? Has anyone changed this out? Is it a pain to get to? I cannot remeber the OBDII code off the top of my head.
  2. #2 Re: O2 Sensor - Bank 1 Sensor 2
    bank one o2 is the one in the rear manifold, bank 2 is post cat.
    post the code, if it could be a vac leak, not a o2.
    if it is the o2, you need a o2 socket to remove it.
  3. #3 Re: O2 Sensor - Bank 1 Sensor 2
    ANNNNNNNNNTTTTTT
    3800's only have one bank because the exhaust is combined into one pipe before the first sensor.
    Bank 1 sensor 1 is in the rear manifold
    Bank 1 sensor 2 is after the catalytic converter
  4. #4 Re: O2 Sensor - Bank 1 Sensor 2
    Apr 2014
    Sioux Falls, SD
    Well, I think I lucked out then since I was not looking forward to getting to the rear manifold.
    When I go to pick up the O2 sensor, I will scan it again and get the code.
  5. #5 Re: O2 Sensor - Bank 1 Sensor 2
    dohhhh.
  6. #6 Re: O2 Sensor - Bank 1 Sensor 2
    sensor one is in the rear manifold. its easy to get out with a o2 socket.
    get it scanned first again. lets make your of what your working with.
    o2 sensors are much cheaper on line, like @ rock auto. so try not to buy one local. shop around get some local prices.
  7. #7 Re: O2 Sensor - Bank 1 Sensor 2
    You posted in the V8 section, assuming your's a GXP, I think the bank 1 sensor is easier to reach but thats not the problem for you.
  8. #8 Re: O2 Sensor - Bank 1 Sensor 2
    Oh shizzle... might be two banks!
    Sensor 2 is always down stream though
  9. #9 Re: O2 Sensor - Bank 1 Sensor 2
    Arizona
    Same applies to all grand prixs/wbody....bank 1 sensor one rear manifold. Bank 1 sensor 2 post cat 02 sensor.
    The V8 does not have dual upstream 02 sensor
  10. #10 Re: O2 Sensor - Bank 1 Sensor 2
    Apr 2014
    Sioux Falls, SD
    Yes these errors are on a GXP. I re-scanned the car today and got P0036, P0054, and P0141. A new code of P0300 just showed up as well but I am guessing it it related the other 3.
    Sent from my iPad using Tapatalk
  11. #11 Re: O2 Sensor - Bank 1 Sensor 2
  12. #12 Re: O2 Sensor - Bank 1 Sensor 2
    Apr 2014
    Sioux Falls, SD
    Thanks guys. I will get that o2 sensor in and see if I can reach the rear plugs.
  13. #13 Re: O2 Sensor - Bank 1 Sensor 2
    i used the o2 socket got it from HF for like 8 bucks. then used 2, 6 inch extensions and a short pipe on my ratchet. this got me just over the sc on my 3800. i know your engine is bigger but if you look back there im sure you'll see it. maybe more or less extensions.
    i didnt rock the engine forward either.
  14. #14 Re: O2 Sensor - Bank 1 Sensor 2
    Arizona
    Pull the coil pack have at it.
  15. #15 Re: O2 Sensor - Bank 1 Sensor 2
    Apr 2014
    Sioux Falls, SD
    Has anyone got this sensor off before? The tool that I borrowed is too short to extend past the u-pipe. I have a wobble on there right now and still cannot get it to bite. Is there a longer o2 sensor socket out there?
  16. #16 Re: O2 Sensor - Bank 1 Sensor 2
    Arizona
    I was able to use a 7/8 wrench and a hammer .
  17. #17 Re: O2 Sensor - Bank 1 Sensor 2
    Apr 2014
    Sioux Falls, SD
    Was it a stubby 7/8" wrench or full length. I tried to wedge a full size one up there but no luck.
  18. #18 Re: O2 Sensor - Bank 1 Sensor 2
    Arizona
    if youre losing to much daylight spray some wd40 on the DP bolts 2x14MM and pull the exhaust down.
  19. #19 Re: O2 Sensor - Bank 1 Sensor 2
    Arizona
    full length with a angled end
  20. #20 Re: O2 Sensor - Bank 1 Sensor 2
    Apr 2014
    Sioux Falls, SD
    I got it. Regular length 7/8" angled just like you said. I attempted to pb blast the dp bolts but would not budge. Whew glad that's over with. Again thanks for all the help.
  1. Replies: 3
    Last Post: 05-28-2013, 05:59 AM
  2. Troubleshooting Misfire and Bank 1 Sensor Errors
    By whathasnt in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-07-2012, 06:26 PM
  3. Where is Bank 1 Sensor 2
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-26-2011, 04:28 PM
  4. "No input to bank 1 O2 sensor"?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 07:11 PM
  5. P0172 rich mixture bank one. oxygen sensor?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2010, 06:49 PM
