Thread: help, newby with 07 Gxp mods and order to apply?
Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
  1. #41 Re: help, newby with 07 Gxp mods and order to apply?
    Either you get a downpipe or headers not both. Headers replace the downpipe. As far as getting one with a Cat..that depends on if you have emissions testing in your area or not. I'm sure 91parkave will chime in here.
    04 Comp G.
  2. #42 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    No emmisions testing in Florida. At least whwre i live. Im assuming the headers would give me a lot more performance than a downpipe
  3. #43 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    SDo you get better performance and sound without the cat?
  4. #44 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
  5. #45 Re: help, newby with 07 Gxp mods and order to apply?
    Arizona
    Headers won't give you the seat in the pants power till your flooring it somewhere, passing etc. Part throttle ispretty much the same although everyone's experience is different. There definatley worth it if you're upgrading other things as well.
    You will get a louder exhaust without the cat. The "power" band feel also shifts up slighty. You will get some better highway mileage as well.
    Remember though you're not deleting the cat without throwing a code you will need a tune
  6. #46 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    I changed spark plugs to ngk and did a raiator flush. Now my display for the outside temperature is off. It is displaying in the 30s when it is actually 80 to 90 degrees out. Any clue why?
  7. #47 Re: help, newby with 07 Gxp mods and order to apply?
    bad temp sensor located in the bumper, its clipped to the middle pass side of the rad support. it looks like a plug just ends. its a little thing that plugs into a pig tail.
  8. #48 Re: help, newby with 07 Gxp mods and order to apply?
    Jan 2014
    United States
    are u sure your aftermarket alternator isnt a 190amp? when i redid the wiring harness in my monte i put a 190-220 amp alternator on it before i put the motor back in the car because i plan on puttin a wall in the back of the car. at idle it runs about 190amps and at 1800 rpms or more it can run from 200-220 amps
    THE RIDES OF 2014​ 98' dodge ram 1500 sport/raminator-DD
    97' ford f-150 xlt-mud toy
    97' monte carlo z-34-project never to be done
    05' grand prix gxp-weekend warrior
  9. #49 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    It might be a 190 amp. Ill have to check sometime this weekend.
  10. #50 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    What are decent or good rotors and brake pads for the 07 grand prix gxp? Mine have some deep grooves.
  11. #51 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    I changed the ambient temperature sensor and it's still reading in the 30s. Any thoughts? My ac is also having problems. Sometimes it blows cold and sometimes it doesn't. The Times it does is when I'm driving. My compressor is not moving when it isn't blowing cold air. I checked the Freon while the compressor was going and it was in the middle of the green. Some days it won't come on at all. I checked the relay and the fuse for the compressor and they are both good. I'm lost. Gonna take it to an auto shop, Just don't want to drop a ton of money on it. Had other plans, but oh well. I'll keep trying til Friday when I take it to the shop.
  12. #52 Re: help, newby with 07 Gxp mods and order to apply?
    If the ambient temp sensor reads below 30-40 degree's it will not cycle the AC on and off.
    That could be the problem.
  13. #53 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    Any idea on why my sensor is reading that low? I replaced it with a new acdelco one from advanced auto
  14. #54 Re: help, newby with 07 Gxp mods and order to apply?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Did it get changed to Celsius?
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  15. #55 Re: help, newby with 07 Gxp mods and order to apply?
    ^^That's probably it.
    Check the settings on the DIC.
  1. brake apply sensor failing?
    By Jesterville in forum 5.3L V8 (LS4)
    Last Post: 04-11-2015, 08:04 AM
  2. Forward apply band
    By GTPgasm in forum General Grand Prix Discussion
    Last Post: 04-16-2014, 05:39 AM
  3. Mods and order of importance
    By Yarbeau in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2013, 02:21 PM
  4. heres the order of mods...
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2009, 05:38 AM
  5. Order of mods and feedback requested
    By diesan04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2008, 10:21 PM
