Thread: help, newby with 07 Gxp mods and order to apply?
Results 21 to 40 of 55
  1. #21 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    I'll probably just do a pan drop then. Out of curiosity, why would a flush hurt though?
  2. #22 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    Sorry, just trying to learn
  3. #23 Re: help, newby with 07 Gxp mods and order to apply?
    never flush a tranny if you dont know its service history. truth is most dont service them at all.
    service should be done by 60,000 a flush is fine if the tranny is working and the fluid looks good still. or sooner if you live in a hill fulled area or real hot temps outside.
    i got my last gmc truck new. i flushed it every 30,000 miles. aka every year in my case lol
    what happens is theres clutch material held in the fluid its helping the clutches work. take all the old fluid out and the old clutch material and your car can stop moving asap. seen it happen.
    safe thing to do is a pan drop and 8 new quarts of tranny fluid with a filter, add a shift kit while the pan is off. they also help keep the trans living longer ( if your not beating the crap out of it daily) being your in Fl you may want to add a trans cooler too if your trans temps are over 200.
  4. #24 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    I appreciate he info!!! I didn't know that. Now I just need advice on spark plugs and wires and anything else I should do for a tune up.
  5. #25 Re: help, newby with 07 Gxp mods and order to apply?
    heres a shift kit how to. it covers the pan drop as well and everything you need http://www.grandprixforums.net/threa...ailed-Pictures
  6. #26 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    I have right under 115k miles BTW
  7. #27 Re: help, newby with 07 Gxp mods and order to apply?
    Apr 2013
    South Carolina
    I recently bought a 08' GXP, and I'm doing a complete trans flush this week. My car only has 50K miles on it.
  8. #28 Re: help, newby with 07 Gxp mods and order to apply?
    Quote Originally Posted by spacerabbit69 View Post
    just a pan drop for you for sure then
    Quote Originally Posted by eighty3bordeaux View Post
    make sure your fluid is still RED and not burnt smelling those v8's tear up these trannys. if the fluid is dark or burnt smelling do not flush it. just do a pan drop and filter change.
  9. #29 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    Poly motor mount or flip the motor mount? Which is better?
  10. #30 Re: help, newby with 07 Gxp mods and order to apply?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Depends if you want to spend money or not, flipping takes like 5 min and is free. But poly is way more solid, might fell vibration at idle with poly.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  11. #31 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    Do the other mounts help if you chamge them or mainly just the top one?
  12. #32 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    http://intense-racing.com/PROD/LS4-PRO-UMMP.html
    These are the right ones? You cant buy just one can you?
  13. #33 Re: help, newby with 07 Gxp mods and order to apply?
    Apr 2012
    Dayton, OH
    Im not sure if GXP lower mounts are the same as 3800 mounts or not but if they are check to see if are leaky and broken looking then replace with solid mounts or new regular ones.
    2012 F150 STX
  14. #34 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    These are the right ones for an 07 gxp?
    Which is the better manifold, ls6, im guessing? Im gonna get headers, which ones are best, and do i still need a downpipe if i get headers?
    Also, what about maf sensors?
  15. #35 Re: help, newby with 07 Gxp mods and order to apply?
    Donating Users timboku's Avatar
    Montgomery, IL
    Change plugs and wires if its over 100k...just put factory wires and plugs in..it will livin up the car for sure if they hsve.t been replaced yet.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  16. #36 Re: help, newby with 07 Gxp mods and order to apply?
    Arizona
    Quote Originally Posted by timboku View Post
    Negative- you'll want to replace plugs and wires a lot sooner than 100k..especially the LS4 do not get factory woresets nor plugs either NGK tr55' or tr6. Msd wires
    Obx have turned out good. Doug thorleys are good too there ceramic coated. Also the ls6/2 are good manifolds ad well.
  17. #37 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    I appreciate the advice. Ill look for thoe headers and manifolds. I changed the spark plugs maybe 30 or 40k ago. Put in bosch iridium platinum fusions and msd wires. Gonna go with the ngk6IX i guess, if thats what you recomend. Heard the same from others too
  18. #38 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    Ive been told to get poly mounts. One guy has square and round. I thought it was one or the other? Is this just the mount by the radiator they are talking about? If it is one or the other which ones are better?
  19. #39 help, newby with 07 Gxp mods and order to apply?
    Squares are for the mount closes to the radiator.. The circles are for the dogbones.
    Generally the squares make way more of a difference. The dogbones circles well many of us leave those alone and stick with the stock rubber ones. Some guys complain of the vibration with them, others aren't bother by it. My suggestion try the squares first then go from there.
    04 Comp G.
  20. #40 Re: help, newby with 07 Gxp mods and order to apply?
    May 2014
    Panama City Beach
    Thanks. Alright, now I've also been told to get a downpipe. I have a magnaflow catback exhaust all the way down. Should I still get a downpipe? And if so, should I get one with a cat? And would I still be able to get headers?
  1. brake apply sensor failing?
    By Jesterville in forum 5.3L V8 (LS4)
    Last Post: 04-11-2015, 08:04 AM
  2. Forward apply band
    By GTPgasm in forum General Grand Prix Discussion
    Last Post: 04-16-2014, 05:39 AM
  3. Mods and order of importance
    By Yarbeau in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2013, 02:21 PM
  4. heres the order of mods...
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2009, 05:38 AM
  5. Order of mods and feedback requested
    By diesan04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2008, 10:21 PM
