Thread: Tension pulley
Results 1 to 7 of 7
  1. #1 Tension pulley
    Jun 2012
    WBL MN
    I'm installing my new alternator and just need to get the belt on, but the tension pulley looks to be in a bad spot. I rented the tension loosening kit from the local parts store and figured it'd be easy, but I can't seem to get the 18mm socket on it. Anyone else have any trouble with it or have any tips? Should I try from the bottom of the car? Any help is appreciated.
  2. #2 Re: Tension pulley
    Arizona
  3. #3 Re: Tension pulley
    Jun 2012
    WBL MN
    Thanks!
  4. #4 Re: Tension pulley
    Jun 2012
    WBL MN
    Is there a certain trick to it? I bought and tightened a 4" clamp around that spring like in the picture and the belt isn't any looser....I went and bought a 18mm wrench head for the tension tool and I can't get anything to get over the bolt either...
  5. #5 Re: Tension pulley
    Arizona
    Gotta keep tightening down then man I slip the belt off at the idler pulley.
  6. #6 Re: Tension pulley
    Donating Users timboku's Avatar
    Montgomery, IL
    Yup.keep tighting the clamp..I used this method works great.it takes alot of tightening but it will compress.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  7. #7 Re: Tension pulley
    Oct 2016
    San Antonio TX.
    This worked like a champ for me !! Thanks,saved the day
  1. o4gtp runnin hot bad tension pulley
    By blackcompg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2010, 01:52 PM
