Thread: o4gtp runnin hot bad tension pulley
Results 1 to 20 of 21
  1. #1 o4gtp runnin hot bad tension pulley
    Dec 2010
    miamigardens
    my o4 gtp compg is runnin hott n i have brown sludge n my radiator n motor i thinkin its my supercharger tension idler pulley i hear a squeakin sound from by my water pump
  2. #2 Re: o4gtp runnin hot bad tension pulley
    Er uh...Hi.. welcome.
    Do you need some procedures for all the work you are about to do or are you bringin her into a shop?
  3. #3 Re: o4gtp runnin hot bad tension pulley
    sounds like coolant flush, new pulley, new water pump at the very least.
  4. #4 Re: o4gtp runnin hot bad tension pulley
    Darn Matt...nice job on the move to the proper section, but ya make me saying welcome and not giving the advice look kinda... doucheee lol
    Don't say it.. Don't... Eh...I said Don't... I know Canadians..
  5. #5 Re: o4gtp runnin hot bad tension pulley
    Darn Nick...nice job on the move to the proper section
    Fixedededdddd...
  6. #6 Re: o4gtp runnin hot bad tension pulley
    Shouldn't we call you Sam? ... Christ..that f'n first name thread has me wondering about my own name. I need a drink, but Nick emptied the fridge as usual.
  7. #7 Re: o4gtp runnin hot bad tension pulley
    He always does...even at my place. Maybe we need to empty all the booze into pop bottles to throw him off
  8. #8 Re: o4gtp runnin hot bad tension pulley
    You forgot that we can piss into the beer bottles to simulate the correct color beverage.
    OP...I'd be sorry for off tracking your topic...but I'm laughing too hard.
  9. #9 Re: o4gtp runnin hot bad tension pulley
    Your not the only one.
    To try and keep this in the same zip code...sounds like you've got teh case of the dexlove. Remove the supercharger belt and start it...if the sound goes away then you know for sure it is a pulley related to the blower.
  10. #10 Re: o4gtp runnin hot bad tension pulley
    I was sooo gonna suggest we send him out for a mechanics stethescope. More tools are always a good thing.
  11. #11 Re: o4gtp runnin hot bad tension pulley
    What the hell is going on in here?
    Brown sludge, pee in beer bottles, bad pumps...wtf
    Matt you forgot to mention that he should check his thermostat, if it ain't opening, its backing up and could damage the water pump as well as not cool. He should just replace it anyways for the $2 it costs
  12. #12 Re: o4gtp runnin hot bad tension pulley
    Dec 2010
    miamigardens
    wen the car getts hot there is water cumin from that plastic elbow from the water pump to the engine..i changed the termostat n the watter started flowin but n think it got stuck again...if i just change my radiator n fix my pulley will every thing be ok..will i have a problem cuz my temp went n the red
  13. #13 Re: o4gtp runnin hot bad tension pulley
    well did you shut it down and let it cool off?
  14. #14 Re: o4gtp runnin hot bad tension pulley
    Air bubble. Crazy temp fluxuation. And its probably right by the T-Stat...bleed the sytem while its running.
  15. #15 Re: o4gtp runnin hot bad tension pulley
    Dec 2010
    miamigardens
    any one n miami..i wanna rebiuld my 04 gtp
  16. #16 Re: o4gtp runnin hot bad tension pulley
    If the coolant elbow is leaking... I'd think that's a thing that needs to be fixed.
  17. #17 Re: o4gtp runnin hot bad tension pulley
    Pennsylvania
    That makes too much sense. Fix her 'till she breaks!
  18. #18 Re: o4gtp runnin hot bad tension pulley
    Nov 2009
    Grand haven
    Just take it to the shop.
  19. #19 Re: o4gtp runnin hot bad tension pulley
    Please.
  20. #20 Re: o4gtp runnin hot bad tension pulley
    GT Level Member starscream5000's Avatar
    Kentucky
    I don't think this is one of those cases where you tell the OP to go get this and go get that, put it in and you're good to go... Take it to a mechanic, explain what is going on, mention the plastic elbow needing to be replaced, get an honest quote.
    If you don't like those numbers they give you, then start rolling up your sleeves and prepare to get dirty and possibly mess it up even more than it already is if you have no mechanical inclination at all.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  1. For people runnin 225/60/16 tires, I need your help right MEOW!!
    By Fivefingerdeathpunch in forum Tires & Wheels
    Last Post: 11-09-2010, 12:55 PM
  2. runnin hot
    By samborski06 in forum General Tech Discussion
    Last Post: 06-18-2009, 01:46 AM
