Thread: LS4 gauge install question
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 95
  1. #1
    I live here. DirtDog's Avatar
    Jun 2012
    Hard to understand Internet sarcasm over...the...well internet lol. Just gotta be sure.
    Yup I feel ya...well back on topic...I'll come up with some more gauges ideas...I've completely searched the glow site and have seen tons of gauges and I can't use a dang boost gauge....errrr
    Sent from my DROID RAZR using Tapatalk 2
    Back on topic
    Get a gigawatts gauge if you get it high enough you can poof into the future!
    04 Comp G.
    Jun 2012
    Back on topic
    O wow...that sounds like it could actually work...sold
    Lol but being the LS and already having the DIC tell you most everything you'll every need to know.. Really the 3rd gauge is going to be something rather useless.
    04 Comp G.
  5. #5 Re: LS4 gauge install question
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    My DIC is so tiny, it's pretty much useless. So I think I might just cut off my DIC. I mean, if none of the ladies in my car like my DIC, then why keep it? I'll just turn it into a cubby to keep stuff in.
  6. #6 Re: LS4 gauge install question
    Jun 2010
    Illinois.
    Get a boost gauge. That way it will motivate you to turbo when you look at it and get sadface when it doesn't read anything.
    Jun 2012
    Quote Originally Posted by Koniig View Post
    I like this guys thinking. I'm gonna wait till after I get back from deployment next year to put a built tranny in and learn to put a turbo in.
    Edit: but until then I want something that's not gonna scream ur car sucks the entire time I'm driving it
    ^ hatchet vs genitals
    Please don't do it
    04 Comp G.
  9. #9 Re: LS4 gauge install question
    Jun 2010
    Illinois.
    Quote Originally Posted by marines542 View Post
    Lmao. However, Pontiacs tend to do that regardless of what you throw at it.
    Please don't do it
    Get your mind out of the gutter, Red. I was talking about my Driver Information Center. Geezzz.
  10. #10 Re: LS4 gauge install question
    Yoga city
    my dic is red, my old dic was blue im rocking an LS whats it to you?
    To late
    FWD + LS + discontinued make + 4 doors = ill let you answer that lol scroll down for the answer to confirm
    Already sucks
    04 Comp G.
  12. #12 Re: LS4 gauge install question
    Arizona
    IMO volts are pointless just get a air/fuel ratio gauge and call it a day But like i mentioned earlier something like the MSD dashhawk could easily take place of all your gauges and mount next to your a pillar on the dash and you would have pretty much all engine paramters at a glance. I think gauges are obsolete now compared to multi function displays
    Quote Originally Posted by 91parkave View Post
    A/F is a bit pointless unless he's doing his own tuning or having a in car tune. Plus $100+ yea costly just to have it to fill his pod.
    04 Comp G.
  14. #14 Re: LS4 gauge install question
    Arizona
    NOtice i didnt say a wideband a/f setup. A narrowband A/F is about the same price as a volt gauge however i dont think glow shift sells them. and another idea is oyu could always use a boost gauge because it will also show vacum which we have you just wont pass 0 lol
    Oops misread your post..lack of sleep.
    04 Comp G.
    Jun 2012
    Thanks for the info. When I get on my computer later I'll look up a/f gauges and look at some write ups for installing and see what I come up with
  17. #17 Re: LS4 gauge install question
    Arizona
    A/F is easy all you need to do is run your signal wire to the engine bay. Find your 02 sensor in the back the harness for it leads up to the rear coil packs dead center. Find the purple wire and splice it on to the existing connection. Do your power and grounds with the rest of your gauges and your good to go. AND MAKE SURE YOU USE A FUSEABLE LINK for power to your gauges.
    Jun 2012
    That seems very simple and easy. As for powering the gauges im also ordering a wiring harness from glow shift that can power and ground up to 4 gauges. And as for the dimmer light I'm putting a manual switch in next to my aux switch so I can dim it when I want
  19. #19 Re: LS4 gauge install question
    Yoga city
    manual dimmer? jut wire it in to the stock lighting, all my leds are like this,the door pods, door cubby holes, and the cubby under the deck, as well as the suttle ones near my feet
    Jun 2012
    Quote Originally Posted by JTeske88 View Post
    Yea but then when ya open a door or turn those lights on they dim. I don't always want them dim lol plus u have several extra switches laying around and I'm good at soldering
  1. help me install my boost gauge!
    By des19 in forum General Tech Discussion
    Last Post: 08-22-2012, 06:01 AM
  2. Oil pressure gauge install help please
    By szalajka05 in forum Audio, Security & Visual Electronics
    Last Post: 12-18-2011, 07:54 PM
  3. Gauge install help...a-pod
    By blortz in forum Audio, Security & Visual Electronics
    Last Post: 07-31-2011, 11:26 AM
  4. Gauge pillar install
    By jdmgtp in forum General Tech Discussion
    Last Post: 06-17-2010, 06:17 AM
  5. AFR gauge install
    By amwhitey in forum General Tech Discussion
    Last Post: 02-03-2010, 01:25 PM
