Thread: GXP Engine noise
Results 1 to 13 of 13
  1. #1 GXP Engine noise
    SE Level Member rguy200073's Avatar
    Sep 2012
    Pittsburgh, Pennsylvania
    Just curious to see if anyone else has experienced this sound before. The video really doesn't bring out the sound but you can kind of hear something. What I notice upon revving, or just low speed acceleration, is a sound similar to that of a turbo spooling. It is coming from the pulleys but I cant determine if it is from the alternator, or tensioner. Any ideas or thoughts?
    06 GP GXP | 1 of 868
    04 GTO M6 | 1 of 889
  2. #2 Re: GXP Engine noise
    sounds like it could be a bad pulley. take the belt off fire it up for a minute, see if it goes away.
  3. #3 Re: GXP Engine noise
    Sep 2012
    Take it off? Wont that mess something up? LOL
  4. #4 Re: GXP Engine noise
    Quote Originally Posted by rguy200073 View Post
    only run the engine for a minute or 2 to hear if the sound is gone. the only thing is the water pumps not turning, so if you run it for maybe 10 minutes or more it may over heat.
    you'll know if the sound is gone right away, if it is, then start rolling your pulleys around to find a bad one. the one that feels loose or wobbly is the bad one. more then likely a idler or tesioner pulley.
  5. #5 Re: GXP Engine noise
    Sep 2012
    How much do those run? Will it just get progressively worse or will it just break?
  6. #6 Re: GXP Engine noise
    depends, any where from 10 to 40. if one breaks the belt can wrap up and do more damage. it should be dealt with in a timely fashion.
  7. #7 Re: GXP Engine noise
    GTP Level Member joshv's Avatar
    canada
    not ur belt man sounds more like a pully..
    here is my annoying belt squeek.. listen closely
    http://s1218.beta.photobucket.com/us...6A2EE.mp4.html
    - for some reason by video didnt pick it up... will try outside maybe tomorrow if its not snowing. but its literally squeek.....squeek.....squeek.
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  8. #8 Re: GXP Engine noise
    Sep 2012
    Quote Originally Posted by joshv View Post
    yeah its hard to hear anything. How many miles are on yours?
  9. #9 Re: GXP Engine noise
    Sep 2012
    Ok cool..even though its a DD, I still don't drive it all that often. But once my GTO is back together, I will take it to the shop and have them do what they need to do. For now, I will just drive it like it has a turbo since it "spools" like a turbo lol.
  10. #10 Re: GXP Engine noise
    canada
    in my old 2004 grand prix v6 it used to make winey noises and it was altnator but was when i gave it gass under load..
  11. #11 Re: GXP Engine noise
    Sep 2012
    Update...still running with no issues. I had a friend check it out and he said that it sounds like a PS pump. But not sure. I guess I will just wait until it breaks lol. I know the pump was changed about 30,000 miles ago so I am surprised that it would be going already.
  12. #12 Re: GXP Engine noise
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    It could depend on what it was replaced with. Some aftermarket pumps don't last very well. I have seen that many times.
  13. #13 Re: GXP Engine noise
    Sep 2012
    Another Update....Had our local go fast shop look at the car and give it a once over. The following repairs are needed on the car....Power Steering Pump, Steering Rack, front hubs/bearings, brake booster, 4 new tires to replace the incorrect sized and dry rotted nexen3000s, and a coolant flush and that's it. Not bad for a 105,000 mile car. Anyways, I had them replace the Hubs/bearings since they were real bad and had them flush the brown, sludgy coolant that was causing the cars temp to fluctuate too much. Apparently someone added green coolant to the dexcool. I will have the PS pump and rack fixed soon and new tires put on but I am actually impressed that the car was in this good of shape once I actually had a trusted shop look over the car. Now I just have to deal with the wine from the pump that has progressively gotten louder and louder since I posted this thread. Oh well, it kinda sounds like a S/C! :-)
  1. engine noise
    By carlover89 in forum General Tech Discussion
    Last Post: 01-04-2012, 03:31 PM
  2. engine noise
    By 2004comp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2011, 07:01 PM
  3. Engine Noise
    By Damojo2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2009, 11:16 AM
  4. 98 engine noise
    By jbizach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2008, 07:18 AM
  5. Engine noise help please.
    By mathd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2008, 08:50 AM
