only run the engine for a minute or 2 to hear if the sound is gone. the only thing is the water pumps not turning, so if you run it for maybe 10 minutes or more it may over heat.
you'll know if the sound is gone right away, if it is, then start rolling your pulleys around to find a bad one. the one that feels loose or wobbly is the bad one. more then likely a idler or tesioner pulley.
