Thread: Power Steering Rack
Results 1 to 12 of 12
  1. #1 Power Steering Rack
    Jul 2012
    Syracuse
    First of all I love this car, but it is a piece of ****....I bought it used and have dumped $2-3,000 into it in two years. Now I am being told that my power steering rack is bad. It started with the seal on the power steering pump blowing and having to replace that. There was power steering fluid all over my engine. That removed the whining on the steering, but now the car is not driveable at low speeds because it has not power steering. Once it has movement (gas to the engine), it works. Without it, it is undriveable. Any suggestions. They are quoting me $1,000 to fix this, not including the $400 for the pump.
  2. #2 Re: Power Steering Rack
    a pump cost 70 bucks at the parts store, and is easy to change, the rack can cost up to 250 for a new one or 125 used.
    its a 3 to 4 hour job on your back if you never did one before.
    if you not up to it yourself, find another shop. they are raping you.
    Dec 2010
    DMV
    It's the pump. Mines had the exact symptoms. New pump. Never had the issue again.
  4. #4 Re: Power Steering Rack
    mine was the same way, did the pump first, got nothing, the rack was next. if the rack is leaking change it.
  5. #5 Re: Power Steering Rack
    Jul 2012
    Syracuse
    It just seems a pump should not go at 38,000 miles. Can the defective pump cause the rack to go bad? I dont have the confidence to change these parts, especially on power steering. I am actually going to bring it to a dealer on MOnday. His price was $600 plus an alignment required. I love my Pontiacs but they have caused me more gray hair than my 3 kids......
  6. #6 Re: Power Steering Rack
    i'd stay away from the dealers, they tend to charge a lot more than they should.
    is the pump whining when you drive? if so it would be the pump defiantly. re manufactured stuff is a 30/70 shot how long they last.
    if its hard to turn one way and easy the other, the rack is dieing.
  7. #7 Re: Power Steering Rack
    Jul 2012
    Syracuse
    It started with a lot of noise in the front end. I noticed small drops of fluid on my driveway and thought it was from my 2002 Grand Prix GTP. After that car got totaled two weeks ago by an idiot driver of another vehicle, I noticed the spot still being made and ironically at the same time the car started making noises when turning. That is when I popped the hood and saw the fluid all over the engine. The power steering fuild reservoir was empty. I filled it up, cleaned up the engine and watched. The engine was covered again in short time. I made an appointment at my shop and that evening the power steering went out completely. When the car does not have the gas pedal applying power to the engine, the power steering is gone. So when I am driving slow no under power, it has no power steering at all. Talk about a workout. When I apply gas, it has power steering. I then took it to the shop where they found the pump to have a bad seal. Replaced the pump and had power steering for 5 minutes and now it is gone again. They are going to repalce the pump again and see what happens.
  8. #8 Re: Power Steering Rack
    GT Level Member GMCustomerService's Avatar
    Michigan
    Quote Originally Posted by djb View Post
    I'm sorry you are experiencing this issue with your Grand Prix. Please keep us updated of your dealer visit.
    If you have any questions or concerns, please feel free to contact me privately.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  9. #9 Re: Power Steering Rack
    yeah that sounds like your pump went bad, or a line is leaking real bad.
  10. #10 Re: Power Steering Rack
    Jul 2012
    Syracuse
    A read somewhere on the Forum that there was a recall on the power steering hose. Could that have anything to do with it? How do I know if the recall was corrected on this car?
  11. #11 Re: Power Steering Rack
    with your vin # in had, call any Gm dealer. they will tell you if you have any recalls that have not been done yet.
    the rack is a recall on some grand prixs.
  12. #12 Re: Power Steering Rack
    Texas
    Wish the rack was a recall on mine. Then again it's the magna steer that is out. Pisses me off taking turns at less than 20ishmph and having to turn a car with no power steering. .
    85 Corvette
    01 TA
    03 Z06
  1. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  2. Steering Rack Questions
    By quickster in forum General Tech Discussion
    Last Post: 12-12-2011, 07:02 AM
  3. Sportiest power steering rack
    By BillBoost37 in forum General Tech Discussion
    Last Post: 01-11-2011, 06:36 PM
  4. steering rack
    By GTP Ryan in forum General Tech Discussion
    Last Post: 11-22-2010, 04:04 PM
  5. Power Steering Rack replacement 98 GT
    By Fritcr in forum General Tech Discussion
    Last Post: 04-27-2008, 06:03 PM
