Thread: 2007 GXP - Strange knocking noise to stump the best mechanic
Results 1 to 9 of 9
  1. #1 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    May 2011
    Moore, Oklahoma
    Braking and Acceleration has no effect on the noise so it's not engine RPM related. It's vehicle speed related so related to something spinning at tire speed. If I'm correct, the noise should speed up the faster you go. Inner CV joint?
  2. #2 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    SE Level Member MikeJenkins's Avatar
    USA
    I found it is definatly something with the exaust. I havn't fixed it yet, but the other day it was missing a rubber tie rod or something in the middle of the exaust that was supposed to be holding it down. I replaced both on each side and the noice almost completely went away. It still does it now just around speeds of 50 or greater. Even then its not nearly as bad as before. I'm going to upgrade my exaust soon so hopefully that will stop whatever it is. I'll check out the CV joint as well just in case. It probly is something related to what Dan is saying.
    Thanks for the help guys
  1. Strange Noise from Driver front wheel area
    By tgarison in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2011, 05:36 PM
  2. 3800 s/c knocking noise or piston slap
    By GTPGuRu99 in forum Introductions/Noob Questions
    Last Post: 11-19-2010, 07:03 AM
  3. Knocking Noise While Braking
    By jonrk7 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2010, 02:14 PM
  4. knocking noise. HELP
    By GMtuner29 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 07:39 PM
  5. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
