Thread: 2007 GXP - Strange knocking noise to stump the best mechanic
Results 1 to 9 of 9
  1. #1 2007 GXP - Strange knocking noise to stump the best mechanic
    SE Level Member MikeJenkins's Avatar
    USA
    2007 GXP, with new replaced engine and transmission, thanks to the 100K mile warranty.
    Question:
    I get a strange knocking noise when driving straight, no turning, when I get about 35 mph or faster. The knocking noise is annoying and sounds like somthing underneath the drivers feet slightly to the middle.
    Acceleration and braking has no affect on the the noise. When going up or down a steep hill the sound has more knocking. It sounds like a loose bolt in the exhaust type of sound. Sometimes the sound goes away but will come back.
    I have crawled under the car and used metal heat resistant tape to secure the exhaust sensor wire connectors but that was not it.
    I took it to a mechannic shop and they couldn't figure it out.
    Any ideas?
    Chris
  2. #2 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    SE Level Member Pontiacfanatic's Avatar
    Apr 2011
    SC Oklahoma
    my 07 gxp makes a very vague and almost unaudible knock while at idle, and even less audible while driving. Im gonna swing it by a GM mechanic tomorrow or later this week. Maybe we will have something in common, so ill relay the info.
  3. #3 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    USA
    Awsome man! Hope you can figure out what the noise is in yours. Preciate it.
  4. #4 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    Apr 2011
    Theresa Wisconsin
    Sounds like the media in the catalitic converter has broken loose and is rattling around in there. My buddies GMC truck with the 5.3 in it just did that to him, a little over 100K on the ODO. Just a thought.
  5. #5 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    May 2011
    Moore, Oklahoma
    Braking and Acceleration has no effect on the noise so it's not engine RPM related. It's vehicle speed related so related to something spinning at tire speed. If I'm correct, the noise should speed up the faster you go. Inner CV joint?
  6. #6 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    USA
    I found it is definatly something with the exaust. I havn't fixed it yet, but the other day it was missing a rubber tie rod or something in the middle of the exaust that was supposed to be holding it down. I replaced both on each side and the noice almost completely went away. It still does it now just around speeds of 50 or greater. Even then its not nearly as bad as before. I'm going to upgrade my exaust soon so hopefully that will stop whatever it is. I'll check out the CV joint as well just in case. It probly is something related to what Dan is saying.
    Thanks for the help guys
  7. #7 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    May 2011
    Moore, Oklahoma
    Love trying to diagnose over the internet.
  8. #8 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    Quote Originally Posted by DoubleASE79 View Post
    X2...it blows...ha.
    I was going to say axles or hub assembly...those things are quite possibly the most annoying noises to me next to squealing belts and/or header leaks.
  9. #9 Re: 2007 GXP - Strange knocking noise to stump the best mechanic
    Oxymoron: Civic - Fun IR II IP IDEATH's Avatar
    South
    Ha, I seen this thread and didnt even know it was you. Thats funny.
    "Last night I didn't get much sleep so in the morning I made my coffee with red bull instead of water, I got half way to work before I realized I forgot my car."
  1. Strange Noise from Driver front wheel area
    By tgarison in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2011, 05:36 PM
  2. 3800 s/c knocking noise or piston slap
    By GTPGuRu99 in forum Introductions/Noob Questions
    Last Post: 11-19-2010, 07:03 AM
  3. Knocking Noise While Braking
    By jonrk7 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2010, 02:14 PM
  4. knocking noise. HELP
    By GMtuner29 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 07:39 PM
  5. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
