Thread: Cold Air
Results 1 to 20 of 29
  1. #1 Re: Cold Air
    GT Level Member RedDawnGXP's Avatar
    Indiana
    You won't hurt anything by installing a CAI but if you want an appreciable HP gain it's best to get a less restrictive down pipe in the exhaust.
    Now if you REALLY want some serious HP save up and get this:
    http://www.turbokits.com/grand_prix_gxp_turbo_kits.html
    It comes with a new air intake and a less restrictive exhaust...and everything else!
  2. #2 Re: Cold Air
    Jan 2009
    Farmington Hills, MI
    There are only two things I can think of that she might have heard about. First, if you over-oil your K&N when you clean it some of that oil can get on the MAF sensor, and your engine will run a little rough. It's easy to fix with a (at most) $5 can of MAF cleaner. Second, you'll be getting more air into the engine and the air will flow past the MAF differently, so that can cause you to run very slightly richer or leaner, but not in any way unsafe. I've never heard of any issues that MAF cleaner won't fix and most guys see a little better fuel economy. Also, the computer will adjust the fueling over time.
    2007 GXP, CAI Intake, 85mm MAF, LS6 Intake Manifold, 42# LS3 Injectors, PRC Ported and Milled 243 Heads - 11:1, 224/232-113+5 Comp Cam, PAC 1218 Springs, DT Headers (w/Custom Crossover Pipe), Cutout and Maxflows, TEP Transmission (3.29s), HP Tuned by Me, Pioneer Speakers and MTX Subs, 13.1 @ 108.7 on street tires at full weight.
  1. A/C cold on one side only?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 06-06-2009, 06:56 PM
  2. cold air intake?
    By hodge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2009, 03:48 PM
  3. hello from cold ny
    By ASCStinger in forum Introductions/Noob Questions
    Last Post: 01-11-2009, 12:33 PM
  4. K&N Cold Air Intake
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 07:39 AM
  5. Cold Air
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 12:15 AM
