Thread: Cold Air
Results 1 to 20 of 29
  1. #1 Re: Cold Air
    Donating Users blowfishRus6's Avatar
    g.a.
    true....but like i said your not really getting cold air.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: Cold Air
    Jan 2009
    Farmington Hills, MI
    When I swapped the LS6 intake on I had to change the angle of the elbow slightly. That in turn changed how the air was flowing past the MAF, and it started to read incorrectly (it was about 5% off). The LTFTs (Long Term Fuel Trims) were correcting by 8-10%, so it was really rich. It cost me about 2mpg and the pedal felt like there was a bigger spring under it (I have drive by wire) until I had the MAF curve retuned. A CAI can do the same thing. But when tuned, you should get better mileage unless you have a bad setup and end up with a Hot Air Intake, as was pointed out above. The out of the box K&Ns usually don't mess with the MAF reading too much, but I've heard a few tuners report having to lean things out after a CAI was installed.
    2007 GXP, CAI Intake, 85mm MAF, LS6 Intake Manifold, 42# LS3 Injectors, PRC Ported and Milled 243 Heads - 11:1, 224/232-113+5 Comp Cam, PAC 1218 Springs, DT Headers (w/Custom Crossover Pipe), Cutout and Maxflows, TEP Transmission (3.29s), HP Tuned by Me, Pioneer Speakers and MTX Subs, 13.1 @ 108.7 on street tires at full weight.
  3. #3 Re: Cold Air
    g.a.
    Quote Originally Posted by nmp0098 View Post
    this.
    its slow.
  1. A/C cold on one side only?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 06-06-2009, 06:56 PM
  2. cold air intake?
    By hodge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2009, 03:48 PM
  3. hello from cold ny
    By ASCStinger in forum Introductions/Noob Questions
    Last Post: 01-11-2009, 12:33 PM
  4. K&N Cold Air Intake
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 07:39 AM
  5. Cold Air
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 12:15 AM
