Thread: DoD Question
Results 1 to 7 of 7
  1. #1 DoD Question
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    My MPG has gone from 22-24 to 19-21, and I can't remember the last time I saw a little puff of smoke from the rear. I think my DoD has turned itself off. Is this possible, and will it harm the engine?
  2. #2 Re: DoD Question
    Mar 2014
    Tucson
    IIRC, a MIL will disable the DOD.
  3. #3 Re: DoD Question
    Jul 2016
    Brevard County, FL
    I know it will, if it's a misfire on one of the DoD cylinders. However, I'm not getting any.
  4. #4 Re: DoD Question
    GTP Level Member
    Oct 2014
    I deactivated DOD on my 2012 suburban and gas mileage did not change.
    I deleted it because of the issues it creates.
    I don’t think it can turn itself off without a MIL.
    I bought a Range device to deactivate.
  5. #5 Re: DoD Question
    done a tune up lately? might be time.
  6. #6 Re: DoD Question
    Kemmerer, Wyoming
    I think a check engine light will turn off dod/afm. I can't remember what people typically unplug to get the dod/afm to turn off. When I bought my GXP, I would see poof's of smoke in my rear view mirror from time to time. I turned off the dod/afm and it stopped. at like 120,000 miles I got low oil pressure, ended up being the pickup tube o ring in the oil pan. I also have a lifter fail which necessitated a new cam and lifter set. that happened like 30,000 miles after dod/afm was turned off.
    my gas mileage pretty much never changed the whole time.
  7. #7 Re: DoD Question
    Nov 2019
    WI
    Quote Originally Posted by Hurricane87 View Post
    That smoke will eventually carbon up the rings and score the cylinders causing low compression. I would either by a Range device or a tuner to delete it. My oil consumption went down to zero after I bought and installed a Diablo tuner. You can use the stock 87 octane tune to save money on gas and just delete the DOD. I would do it before the engine is damaged.
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
