Thread: LS4 Oil Pressure Dilemma
Results 1 to 16 of 16
Threaded View
  1. #1 LS4 Oil Pressure Dilemma
    Sep 2017
    Winneconne, WI
    My 2008 GXP intermittently shows Service Engine light. Code is due to oil pressure sensor malfunction. I put a gauge in place today and saw 40 psi at startup, which dropped to about 15 psi within a few minutes as the engine warmed. A fairly loud lifter tick showed up when the pressure was low. I took the car for a drive--about 10 miles--and rechecked the gauge. After thorough warmup, oil pressure now shows 35-40 psi at idle.
    I thought the gage might be stuck, so I shut the engine down and it drops immediately to zero. Startup still shows 35-40 psi at idle.
    Engine has 165,000 miles on it. Oil now in the engine is 5w-30. Filter is AC PF63. Oil consumption is about a quart per 1,200 miles.
    Is there an explanation for the oil pressure variation as I described? Why does a hot engine show more oil pressure at idle than when first starting the engine?
    LS4 Oil Pressure Dilemma Attached Images
  1. Pulley install dilemma
    By kurupt305 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2013, 07:42 AM
  2. Rack and Pinion Replacement Dilemma
    By quickster in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2012, 06:19 AM
  3. Dilemma, what should I do with my car.
    By Lsick7 in forum Off Topic Discussion
    Last Post: 05-25-2010, 01:26 AM
  4. Ok, so here is the dilemma..
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 12-25-2009, 11:56 PM
  5. Suspension dilemma
    By trapguy50 in forum General Tech Discussion
    Last Post: 10-08-2009, 09:41 PM
