Oil pressure problem remains the same. Cold startup pressure at idle is 10-15 psi. Lifters sometimes clatter. After 10 minutes of idling, pressure goes to 25 psi, lifters are quiet. Anytime the engine is revved beyond 1500 rpm, pressure goes to 40+ psi.
Every engine with oil pressure problems got worse as engine warmed up. This is puzzling.
I changed the oil (Quaker 5W30 full synthetic and AC PF63 filter), added 6 ounces of SeaFoam to the oil after reading that some people get "magic" results. We'll see what happens.
A side benefit of unplugging the sensor wires is that the shudder when stopping has gone away completely. As some have told me, the problem is the DOD staying in 4 cyl. mode when stopping. Problem is, the Service Engine Soon light stays on and remote start won't work.
