Thread: Oil Filter Choices
Results 1 to 9 of 9
  1. #1 Oil Filter Choices
    Sep 2017
    Winneconne, WI
    I've been using the AC PF63e on my 2008 GPX. All the parts store websites say this filter will not fit. What have some of you found? I know the PF48 is recommended, but it's a very short filter.
  2. #2 Re: Oil Filter Choices
    The factory filter is short, that is why they say it will not fit.
    Is it this way for tons of GM vehicles, there is always a long and short filter with the same thread pitch but some vehicles get short and other long.
    The LS V8's in the trucks use a 1042 short filter from napa but a 1522 is the long filter that also fits. Or the later model trucks use 7060 but the long version is 7045. If you look up each truck it will show just the short as the only option on a 5.3 engine.
    It was easy to figure out what is the same style when looking up measurements or just working on the vehicles in general because I just just screw on different filter to see what worked.
    I'd rather use a WIX style filter from napa than a AC delco filter but a new filter is a new filter so it's better than nothing.
    FYI, a PF48 is the napa 7060.
  3. #3 Re: Oil Filter Choices
    Sep 2017
    Winneconne, WI
    Thanks for the reply. I will continue to use the PF63e, which is the longer version of the PF48. I don't see value in abandoning what GM put on this engine from the factory--an AC Filter.
  4. #4 Re: Oil Filter Choices
    It's a preference thing and to some a data thing.
    Many tests have been done on all kinda of filters to show quality or construction, pleets (media) and the flow through the oil filter.
    Times could have changed but in the most recent ones I'd read and looked at the AC delco filters did less than other brands because they had less media and flowed faster than other filters because of it. Meaning they didn't trap as much stuff and were used up faster.
    My wix filters are generally cheaper than AC delco and do just as good if not better job at filtering.
  5. #5 Re: Oil Filter Choices
    St. Louis
    I've run nothing but Wix filters on all my cars (except my Crown Vic) and have never had an issue even being higher mileage engines. Also been running them in an 04 5.3 Silverado and an 05 Avalanche for almost a decade (friends trucks). So far no issues.
  6. #6 Re: Oil Filter Choices
    Dec 2013
    Enfield
    I had contemplated running a longer length filter, but for me it hung a little too low for my liking. Did a write up on another site, here is the thread if you are bored
    Extended length oil filters for 07-09 only - LS1TECH - Camaro and Firebird Forum Discussion
  7. #7 Re: Oil Filter Choices
    ran ac delco on majority of my GM vehicles and never had an issue.
    when I had my 98 GTP I ran the truck filter as well. my only issue with the longer filter is that if you have worn bushings or suspension or even lowered, to be wary of hitting bumps and/or pot holes. I had one instance where the truck filter got a bit crushed against the control arm on the passenger side and cracked a small leak. the gtp wasn't lowered but it had a worn control arm bushing IIRC when I hit a bad pothole.
  8. #8 Re: Oil Filter Choices
    Donating User
    Aug 2016
    MI
    I will not use fram after seeing this video. This guy cuts open the filters to look inside and compare how good they are brand vs brand.
    The worst oil filter EVER! - YouTube
  9. Likes Cerberus liked this post
  10. #9 Re: Oil Filter Choices
    Oct 2014
    portland oregon
    Great video.. I usually just get a Delco filter but I'll be getting Wix from now on... FFDP swears by them
    Sent from my SM-N920V using Tapatalk
  1. header choices
    By kking89 in forum General Tech Discussion
    Last Post: 03-05-2014, 07:32 AM
  2. So many choices... what do u guys think???
    By rlvis361 in forum Tires & Wheels
    Last Post: 05-10-2010, 09:59 PM
  3. PLOG choices
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2009, 01:00 PM
  4. Filter off of TB: Choices...
    By Space Dynamics in forum General Tech Discussion
    Last Post: 07-14-2009, 07:58 AM
  5. cam choices
    By popeyenate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 08:17 PM
